I have a iBook G3, and a while ago, the power adapter shorted out.
I'm looking for a new one, anyone know of a good one?
I've heard about problems with the official Apple adapter, so does anyone know a good (and relatively inexpensive) adapter?
iBook G3 need new power adaptor (White Dual USB)
Re: iBook G3 need new power adaptor (White Dual USB)
The "official Apple one" works perfectly fine actually. You can still get them at most any Apple dealer for about $70.
Some dealers sell a "chinese knock off" of the 65W iBook adapter (for your model and lots of others) for about $50. Works fine.
Cheers
chas_m
http://spacejavelin.com
chas_m
Seaglass34
- 2 MB
I just purchased a new one for my MacBook Pro from Amazon, since I had electrical tape around it.
Same as the old one & far less expensive.
