Help with Wireless Internet on a PowerBook 1400
Sawtoothdude
Post by Sawtoothdude »
I have PowerBook 1400cs Running OS 8.1 that i am trying to get running with an Orinoco WaveLAN Silver card. I have tried the Version 6 drivers but to no avail, Is there any other software i can use?
Re: Help with Wireless Internet on a PowerBook 1400
Is your wireless network encrypted? Have you manually typed in the SSID in the WaveLAN control panel? Does it give you any errors? Are you able to set the AppleTalk and TCP/IP control panels to the WaveLAN card?
Sawtoothdude
It is not encrypted, i have typed the SSID, and i don't get errors, However the card onnly shows up as "Ethernet"
What are your TCP/IP settings? Is your router set to distribute DHCP? If so, is your PowerBook gtting a good IP address (like 192.168.1.x) or a self-assigned, which would be like 67.234.something.blah
snoebay88
Post by snoebay88 »
Hello;
Try going to this site http://www.penmachine.com/techie/airport1400.html.Best directions I've seen yet for getting a older powerbook on wi-fi.Have used this site myself for installing wi-fi on a 1400
snoebay
cr2032
Post by cr2032 »
yes, I remember I tried that website before.
the same link :
it mentioned something about the firmware of the wavelan card, too. Not sure if this is applicable to you or not ?
