Installing Windows Vista on Q
I can't figure out how to get Q running with Windows Vista... it won't boot from my DVD and there is no installer helper or anything. Has anyone done this before or know how to do it?
mrkramer
Re: Installing Windows Vista on Q
Post by mrkramer »
I don't know if you already figured out how to do it or not, but is there a reason you don't just use bootcamp? I tried using Q a while ago, and I couldn't figure anything out on it either.
I don't like the idea of running Windows natively on my Mac. I've heard about people messing up partitions and corrupting their installations of Mac OS X.
I've had experience with Parallels on other people's Macs, and it seemed just fine. I figured I'd download the free Q for myself and try it but it won't boot from my Vista DVD.
