radeon 9200 card removal
madmann
Post by madmann »
I updated the graphics card in my quicksilver.
I added a 7500 agp radeon card every think works fine
I removed the radeon 9200 pci card and my machine boots into Darwin dsb login
So i put the 9200 back in and the machine boots into the gui. what is going on. I have no monitor attached to the 9200 it has to be a driver issue.
Re: radeon 9200 card removal
What are you getting video on when it boots into Darwin?
I guess a better question would be what are you trying to achieve ultimately? Video on the 9200?
What machine is this?
madmann
Post by madmann »
i added agp card to the quicksilver dual 1ghz "faster video" and want to remove the 9200 pci card to use in a blue and white. simple right the 9200 is no longer needed
So the blue and white is what you're having problems on? Or the QuickSilver?
madmann
Post by madmann »
no it is the quicksilver that does not work I cant remove the 9200 pci card out of it without booting into darwin black screen with white text
Ouch that does sound like quite a problem.
What sort of haxies do you have installed on this system, if any? Is this an unsupported instal of Leopard by any chance? Regardless of what version it is, did you install Mac OS originally with only the PCI video card installed? (although that shouldn't really make a difference)
squiffy
Post by squiffy »
First thing to try when installing/removing hardware is a PRAM reset. When booting, hold down the command-option-p-r keys until a second (or third or fourth, can't hurt) boot chime is heard. You can also reset the NVRAM by holding down the command-option-o-f keys. A white text on black screen will appear. At the prompt, type "reset-nvram" then enter. Then type "set-defaults", enter. Then "reset-all", enter. Don't type the quotes. The system will reboot.
I'm not sure if the quicksilvers have a cuda (capacitive unit discharge asic) button. If they do, unplug your system, open the case and press it for a few seconds. It should be near the battery.
Good luck.
Anything posted by me is not to be taken seriously.
madmann
Post by madmann »
it appears that the pram was the issue. my quicksilver has booted up twice now without the 9200 installed.
thanks
Wow who would have thought PRAM still caused issues in Mac OS X.
squiffy
Post by squiffy »
Your welcome! Glad to know a simple pram reset cured it.
I guess I have a temperamental G4 tower (agp graphics). Any hardware changes require me to hit the cuda button. Recently removed a hard disk. Reset required. Installed 802.11g card, another reset. I've gotten used to pushing that sucker.
madmann
Post by madmann »
well the machine restarted twice and this morning no go. it is like after some time the 9200 card is required to start up the gui
cuda button is next
madmann
Post by madmann »
well the cuda button did not help either
black screen with white letter login
squiffy
Post by squiffy »
Will it boot normally if you type mac-boot and press enter? Have you tried the pram reset again successfully? If this is required every time, perhaps the battery is dead or dying.
Other ideas:
1. Install latest ATI drivers.
2. Run disk utility when started from your install disk.
3. If you have a utility like TechTool Pro, start from the disk and run it.
4. Select your start up disk in System Preferences, then click the lock to prevent any changes.
