MacCPIO v0.2; a CPIO archive creator utility
Post by Info-Mac » March 15th, 1994, 11:00 am
Download: http://archive.info-mac.org/cmp/mac-cpio-02.hqx
--========================_12745404==_
MacCPIO is a quick and dirty CPIO archive creator utility. The intent was
to write a program for the Mac with a Mac "look and feel" that would
generate a CPIO archive which could then be uncompacted on a Unix machine.
The inspiration behind this was things like SunTAR and the fact that I wanted
to do this at work for archiving lots of Mac source code in a Unix format.
Mostly however, I must confess that it seemed like a nifty little project to
use as a learning example in Mac programming.
Content-Type: application/mac-binhex40; name="MacCPIO_v0.2.sit"
Content-Disposition: attachment; filename="MacCPIO_v0.2.sit"
