InsideScan 1.0.2 - FileMaker plugin for image and file handling
Download: http://archive.info-mac.org/app/insidescan-102.hqx
InsideScan is an image management plug-in that lets you handle your
images in a FileMaker Pro database. Since it is perfectly integrated with
FileMaker Pro, InsideScan allows you to:
- import images directly from TWAIN and Photoshop compliant acquisition
sources (scanners, digital cameras, etc.), and choose to save them on
disk or directly in your container fields;
- import images in your database, by supplying their pathname;
- export images from container fields, in a specified format (i.e. JPEG,
TIFF, PICT, BMP, etc.);
- show an image in a dedicated window, where you can zoom in/out, rotate
and invert the picture;
- edit an image due to a set of drawing tools that allow you to select,
modify, color and erase parts;
- convert images already on disk, from one format to another;
- print images;
- create thumbnails;
- basically manage files.
Minimal system requirements:
* Apple Power Macintosh
* Mac OS 7.6 or later
* FileMaker Pro 4.x or later
* QuickTime 3.0 or later (QuickTime 4 recommended)
