Download: http://archive.info-mac.org/cmp/encryplet-10fc1-as.hqx
I'm attaching to this message the final client version 1 of Encryplet.
Encryplet is a US$5 shareware AppleScript(R) droplet which makes it
easy to encrypt and decrypt files by drag-and-dropping them onto a
Desktop Encryptor icon (similar to the Desktop Printer icons in
QuickDraw GX and System 7.5.1 and later).
Encryplet relies on your AppleScript-aware version of Philip
Zimmermann's PGP software ‚MacPGP(R)‚ to perform encryption and
decryption.
Because PGP also compresses data when encrypting it, Encryplet can
also be useful as an easy-to-use, effective data compression utility
while it secures your private information - I was able to reduce some
text files to 27% of their original size.
cheers;
Raif S. Naffah
Type & Graphics Pty Limited (ACN 061 642 779)
