DandStoQIF2 - Convert from Dollars and Sense to Quicken
Download: http://archive.info-mac.org/cmp/ds-to-qif-converter.hqx
This program should make life easier for those who are converting from
Dollars and $ense to Quicken. It converts a file with transactions
exported from Dollars and $ense to Quicken's QIF format. Source is
included. Macintosh user interface guidelines are NOT followed, but
this should be a program that you only have to use once.
This is a self-extracting archive.
This version automates more of the process than the original version
that was posted in mid-1993. It can take its input from one big report
instead of requiring a separate input file for each account. It
doesn't require hand editing of the input file. It has addresses the
problem of transactions that transfer between two accounts and that are
cleared in both.
This should replace the existing dandstoqif.hqx file in the archive.
