Info-Mac Digest V19 #9
Subject: Info-Mac Digest V19 #9
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Fri, 18 Jan 02 Volume 19 : Issue 9
[*] MySQL deb 3.23.47 for MacOS X
[*] PeriodicTable 3.0.4
[*] PolyRoot 1.0.2 68K
[*] PolyRoot 1.0.2 Carbon
[*] PolyRoot 1.0.2 PPC
[*] XBubbles 1.0J - Japanese Version
[A] appearance lib
[A] Epson scanner program
[A] freezes on G4 dual processor
[A] Reading Toast Cds on Windows Machines
Big 9.1 and OS-X install problem
No power key on Apple Pro keyboard
from the new address.
and Chris Pepper.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V19 #9"
Date: 18 Jan 2002
To:
Subject: [*] MySQL deb 3.23.47 for MacOS X
MySQL 3.23.47 deb package for MacOS X with transaction safe InnoDB table
support. The main advantages of deb packages are:
1) They do not install anything into MacOS X system directories;
2) They do not alter any system file(s);
3) Everything is installed into separate directory tree;
4) debs are very easy to uninstall and upgrade;
5) Data directory is visible in the Finder.
Created with Fink .
Installation instruction enclosed.
[Archived as /info-mac/data/mysql-32347-deb.hqx; 8291 K]
Date: 18 Jan 2002
To:
Subject: [*] PeriodicTable 3.0.4
This is a demo version of Synergy Creations' Periodic Table for Macintosh
software. Version 3.0.4 release date: January 16, 2002. It is designed as
a quick reference tool for high school and college students in introductory
chemistry courses, along with anyone else who needs a quick periodic table
reference. To unlock all the features, there is a $15 registration fee.
Key Features:
- Quick access to a wide variety of atomic properties.
- Relative values of many atomic properties on the periodic table are
viewable as color scales. (only a few in unregistered version)
- Easy switching between various unit scales.
- Clean, clear, easy to understand interface.
- User configurable--choose a table to view at startup.
- Controls and design help to emphasize relationships between elements.
http://www.synergycreations.com/pt.html
System Requirements:
- System 7.5 or greater (Mac OS 8 or 9 recommended)
[Archived as /info-mac/sci/periodic-table-304.hqx; 2462 K]
Date: 17 Jan 2002
To:
Subject: [*] PolyRoot 1.0.2 68K
PolyRoot is a companion application to RPN Calculator (also in this
archive). It is a small application specifically designed to find
polynomial roots. The polynomial can be up to degree 10, and can have real
and complex coefficients. PolyRoot supports drag & drop, which provides
near seamless integration with RPNC.
PolyRoot is freeware.
[Archived as /info-mac/sci/calc/poly-root-102-68k.hqx; 521 K]
Date: 17 Jan 2002
To:
Subject: [*] PolyRoot 1.0.2 Carbon
[Archived as /info-mac/sci/calc/poly-root-102-cbn.hqx; 815 K]
Date: 17 Jan 2002
To:
Subject: [*] PolyRoot 1.0.2 PPC
[Archived as /info-mac/sci/calc/poly-root-102-ppc.hqx; 705 K]
Date: 17 Jan 2002
To:
Subject: [*] XBubbles 1.0J - Japanese Version
This is the Japanese version of the XBubbles package.
XBubbles is a game of logic. The task is easy but the way is tricky. Every turn
five balls of eight different kinds appear on the game field at random. Each turn
you can move one ball to any free position with one exception - a ball can't jump
over another one. Your task is to assemble five or more similar balls in a line in
any direction. When you put last ball in line all balls in that line will disappear
and you get free turn. Your score is calculated by a complex rule, according to
the number of turn's you took, number of extra balls and so on.
XBubbles is the next generation of Bubbles which was written for classic Mac OS
few years ago. XBubbles is completely redesigned and implemented in Cocoa on
Mac OS X.
System Requirement
Mac OS X 10.1 or later is recommended. However XBubbles should run fine on
earlier versions of Mac OS X.
[Archived as /info-mac/game/xbubbles-10-jp.hqx; 275 K]
Date: Thu, 17 Jan 2002 10:31:22 -0800
To: david doran , [email protected]
Subject: [A] appearance lib
At 11:46 PM +0000 1/7/02, david doran wrote:
> Actually its a question rather than priceless thought,- Any
>one aware of
>where I might find Appearance Lib - Use theme font" as Iäm repeatedly
>hitting a crash on certain programmes due to the fact it cannot be found.???
I would try the following:
1) Throw away your appearance preferences
2) Reinstall your system
-----|----- Maurice "Mike" McNeil, BBN Technologies
0-0 (858) 495-2619 (858) 354-6565 (Cell)
(_)+ [email protected] [email protected]
Date: Thu, 17 Jan 2002 10:43:29 +0100
To: [email protected]
Subject: [A] Epson scanner program
>Date: Sat, 12 Jan 2002 21:16:24 GMT
>From: [email protected]
>Subject: Epson scanner program
>MIME-Version: 1.0
>Hello!
>First, what I have:
> G4
> OS 9.1
>16 GB free on drive
>256 RAM
>virtual memory on
>USB connection through port 3 of a four-port hub
>I just bought an Epson scanner 640U. I have Omnipage Pro ver 7, which
>Epson says is supported by this scanner. But in order to use it, I must
>get to the Scan Assistant for the scanner, and I can't.
>Specifically:
> I open "smart panel"
> All the options work EXCEPT "scan to ocr", which of course is the one
>I need.
> And I am stuck.
>I have uninstalled and reinstalled twice.
>I do not have a "Language" kit installed.
>Autovirus protection was off during installation.
>Epson/Newsoft, online, in guides, or in tech support are absolutely
>WORTHLESS.
>Before I take the scanner back, any ideas that I could try?
>TIA!
>Polly
I have a couple of suggestions you could try.
1) Try connecting the scanner directly to the computer rather than
the hub. This often helps with scanners.
2) A work around. Using the Epson scanner software scan your document
in Black and White (important) at 200 to 300 dpi. Save it in TIFF
format to a file. In Omnipage you can then import the file instead of
scanning directly. After converting the file I would trash it because
they can be quite big, especially if you're scanning a full A4 page.
Its a few extra mouse clicks but should work.
Hope this helps
Paul
Paul Dagleish
mailto:[email protected]
Date: Thu, 17 Jan 2002 10:46:55 -0800
To: Ken Laskey , [email protected]
Subject: [A] freezes on G4 dual processor
At 11:18 AM -0500 1/15/02, Ken Laskey wrote:
>Any suggestions would be appreciated.
Ken,
I cannot answer the question about the memory - I assume you have
done all the system "grooming" that might address this issue also:
1) Rebuild the Desktop using TechTool (http://www.micromat.com), this
is a free tool that actually deletes the desktop and rebuilds it from
scratch, much better than just holding down command-option.
2) DiskWarrior to optimize the directory structure
3) Norton, Techtool Pro, etc. to examine and repair disk media, file
structures, etc.
System freezes can be caused by any and all of the problems addressed
by these applications. I personally use all of them at various times.
Techtool should probably be done monthly - hope this is of some help.
Date: Thu, 17 Jan 2002 10:00:57 -0500
To: John Fitzgerrel , [email protected]
Subject: [A] Reading Toast Cds on Windows Machines
To read the CD on a Windows machine, you have to do a single burn;
Windows software does not know about sessions. I think this is
discussed in the Toast manual, but I'm not positive.
Ken Laskey
Date: Thu, 17 Jan 2002 20:40:05 -0500
To: all macs all macs ,
Subject: Big 9.1 and OS-X install problem
I've been trying to install both OS 9.1 and OS-X on my son's iMac (rev b/233
mhz) and both are a no-go. It runs well on OS 9.0.4 but when I try to
install 9.1 it refuses to reboot off the hard drive. It used to just flash a
"?" until a CD was installed, and then it would automatically start off the
CD. Now it flashes the ? then shows the following message:
Apple iMac open firmware 3.0.f2 built in.....(etc)
Copyright 1996-1999
ok
0 > _
(where it expects me to type something in.)
If I pull the drive out and install it into my G4 it boots perfectly. I'm
thinking its a firmware upgrade problem with the iMac. but none are listed.
When installing OS-X 10.0
it goes through to the point where you choose a hard drive to install to,
but the drive is locked out. thus I have to quit and restart. I tried
installing OS-X with both 9.0.4 and 9.1. I had the same results both times.
The iMac has 192 megs of ram.
The drive is a Maxtor Diamond plus 40 gig formatted by Apple's Drive setup
as an HFS+.
HELP!!!
John
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
Date: Fri, 18 Jan 2002 04:15:11
Subject: No power key on Apple Pro keyboard
and, for that matter, how does one restart a G4 without turning the power
off if it hangs (which, of course, they still do)
>This may sound like a stupid question, but how does one turn on a Mac now
>that Apple's removed the power button from the Apple Pro Keyboard?
>This was always one of the most elegant things about the Mac OS...
>Thanks,
>E. Blasberg
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
--Info-Mac-Digest--
