Decoder.dmg - Submission of Decoder X 3.0
Download: http://archive.info-mac.org/cmp/decoder-30-x.hqx
Decoder 3.0 - This is a drag and drop program that will decode yEnc, MIME
(Base64), UUencoded, AppleSingle, MacBinary (I, II, and III), and BinHex
files.
Just drop the files onto the application and it will determine the correct
encoding scheme and decode accordingly. Converts MIME files info HTML. Works
great with newsreaders and AOL e-mail. Thousands of satisfied users.
Requires: MacOS X 10.2
Classic MacOS and Windows versions are also available.
Shareware - $ 20.00
John Daniel
Etresoft
www.etresoft.com
