Download: http://archive.info-mac.org/cmp/decode-da-code-15.hqx
Version 1.5 of Decode da Code adds two new options for handing filenames and
post-processing. Decode da Code is an application which takes base64 and
uuencoded binary file attachments commonly found on email and newsgroup
postings, and decodes them into a more useful format.
The new version adds an option to disable launching post-processing
applications, and another option to truncate the extensions off of long
filenames.
Decode da Code is built for Mac OS X, and is a Carbon App, which means that
you can use it in Mac OS X without having to run the Classic environment.
Decode da Code Page - http://www.felttip.com/products/decode/
