Subject: Info-Mac Digest V18 #138
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Tue, 30 Oct 01 Volume 18 : Issue 138
5400/200 RAM Question
[*] 7th Guest PowerPC Patch readme
[*] DragThing 4.2
[*] DragThing D-4.2 (German)
[*] DragThing F-4.2 (French)
[*] DragThing J-4.2 (Japanese)
[*] DragThing T-4.2 (Italian)
[*] EnglishLeagueManager115
[*] Glypha III 1.1b2J - Japanese Version
[*] Haxial DiskCatalog 1.000
[*] Osaifu weekly1.0 Japanese
[*] RPN Calculator 1.4.4a 68K
[*] RPN Calculator 1.4.6 Carbon
[*] RPN Calculator 1.4.6 PPC
[*] TidBITS#603/29-Oct-01
[*] URL Manager Pro 3.0b18J - Japanese Version
[*] VersionLoader 1.0a2 (MacOS X version)
adapter for small power plug
DVD region fixer
Extensions Mgr: Error -116 on save Missing Extensions
Mac avi players
Old Afga Slidewriter
pc card problem
software for USB pci card?
Software Update Crashes
from the new address.
and Chris Pepper.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V18 #138"
Date: Sun, 28 Oct 2001 11:17:37 -0500
To: [email protected]
Subject: 5400/200 RAM Question
I have a 5400/200 PowerMac. It came with 8 meg of RAM on the MB and a 16
meg DIMM in Dimm Slot #1 (24 meg total). I wanted to upgrade to OS 8.6,
so I recently bought a 64 meg DIMM, thinking I would put it in Slot #2,
thus having 88 meg of RAM: 8 on the MB, 16 in slot #1 and 64 in Slot #2.
Unfortunately, when I put the new DIMM in Slot #2 I rebooted and the
About This Macintosh window showed I only had 56 meg of physical memory.
I tried switching the DIMMs, putting the 64 in Slot #1 and the 16 in
Slot #2, but it still shows only 56 meg of physical RAM.
What am I doing wrong? Do I need to reconfigure something on the MB (a
jumper or something) or in the OS (I did get 8.6 installed successfully
with the increased memory available)? The arithmetic shows that it is
only recognizing 64 minus 8, leaving 56. I think the new DIMM is
correct, as it has 64 meg clearly printed on it. Maybe there's a limit
if the two dimms are not the same size?
If anyone knows about this problem, or has any suggestions I'd
appreciate hearing from you, either through the digest or directly. I've
checked apple-specs and apple-history, but neither of them tells of a
unique problem with installing expanded RAM in this model.
Sam M. Hunter
[email protected]
Date: 27 Oct 2001
To:
Subject: [*] 7th Guest PowerPC Patch readme
______________________________________
7th Guest PPC Patch
Written April 16, 1995 by John Stephen
Disclaimer
This is an UNOFFICIAL patch for The 7th Guest . I am not an employee of
Virgin Games nor do
they have any idea that I have created this patch. This application has not
been tested
extensively and may have bugs or cause problems with The 7th Guest .
However, given that
The 7th Guest already has serious problems with Power Macintoshes, and
given that I havent
experienced any problems myself while playing a patched version of the game
on my Power
Macintosh, I dont believe there is any serious risk with using this
software.
What it does
This application fixes a Power Macintosh incompatibility with Virgin Games
The 7th Guest .
This fixes a random crashing problem which occurs while playing the game on
Power Macintosh
computers (ie - PowerMac 6100, 7100, or 8100). This crash is caused by a
bug in the part of the
games code which controls the mouse/cursor in the game and that bug is fixed
by this patch.
How to use it
You must have already installed The 7th Guest on your Macintosh before you
can use this
application to patch your game. This application can only patch the copy of
The 7th Guest
which is installed on your hard drive -- it can not patch the copy on the
CD-ROM (CD-ROMs cant
be modified).
Before using this application, make sure that any virus protection software
that you are running
********** ABSTRACT CROPPED **********
[Archived as /info-mac/game/com/7th-guest-ppc-patch.hqx; 11 K]
Date: 27 Oct 2001
To:
Subject: [*] DragThing 4.2
DragThing is the original dock designed to tidy up your Macintosh
desktop. Simply drag an application from the Finder onto an empty
square in a dock and then drag documents onto it as normal.
Click a docked application to launch it or bring it to the front.
In addition, the docks can contain files, folders, disks and servers,
and there is also an option to display the currently running processes
in a special dock.
Major new features in this version include:
* DragThing uses the native Quartz graphics of Mac OS 10.1 for an
improved Aqua appearance, including an option for translucent docks,
and anti-aliased icons.
* You can put the Trash back on the Desktop where it belongs
on Mac OS 10.1.
* You can bring all the windows of an application to the front
automatically when you switch to it, or by using a hot key.
* Improved hierarchical contents menus for folders, including
support for aliases.
* Greater control over how dock items are located, using a
combination of aliases and full paths.
* Support for "Super Get Info" by Bare Bones Software.
A full list of all the changes is here:
This is a free upgrade for existing registered users of DragThing 4,
$10 for registered users of previous versions, and $25 for new users.
Competitive upgrades are also available for $19 to users of Aladdin
DragStrip 3 and PowerOn ACTION GoMac 2.
DragThing is a Carbon application which runs natively on Mac OS X,
and on Mac OS 8.6 and 9 with CarbonLib 1.1 or later installed.
James
[Archived as /info-mac/gui/dragthing-42.hqx; 1956 K]
Date: 27 Oct 2001
To:
Subject: [*] DragThing D-4.2 (German)
DragThing D-4.2 is the latest German language version of my
dock application DragThing.
For more information, check out the official DragThing website at:
James
[Archived as /info-mac/gui/dragthing-42-de.hqx; 1975 K]
Date: 27 Oct 2001
To:
Subject: [*] DragThing F-4.2 (French)
DragThing F-4.2 is the latest French language version of my
dock application DragThing, translated by Philippe Bonnaure.
and Philippe's translation site at:
James
[Archived as /info-mac/gui/dragthing-42-fr.hqx; 2017 K]
Date: 27 Oct 2001
To:
Subject: [*] DragThing J-4.2 (Japanese)
DragThing J-4.2 is the latest Japanese language version of my
James
[Archived as /info-mac/gui/dragthing-42-jp.hqx; 1949 K]
Date: 27 Oct 2001
To:
Subject: [*] DragThing T-4.2 (Italian)
DragThing T-4.2 is the latest Italian language version of my
dock application DragThing, translated by Massimo Rotunno.
and Massimo's translation site at:
James
[Archived as /info-mac/gui/dragthing-42-it.hqx; 2082 K]
Date: 27 Oct 2001
To:
Subject: [*] EnglishLeagueManager115
English League Managerv1.15 is a shareware soccer management game.
Version 1.15 has many improvements including better player transfers.
ELM allows you to manage a team within the English league. The ultimate aim is to win the Premier Championship and both the FA and League Cups within the same season.
FEATURES
* Manage a team from one of the 4 main English Divisions using over 90 screens.
* Play three types of game - Standard, Manager's, and Custom.
* Over 4000 players in 124 clubs: - up to 25 players in squad & up to 25 in reserves.
* Player roles - goalkeeper, defender, midfielder, forward.
* Players have 17 attributes:.
* Moving match play allowing substitutes,injuries, corners,free kicks, red cards.
* Match animation is 2D but hidden simulation uses 3D space for ball.
* The ability to change formation and general tactics during a match.
* Training ground for practicing corner and free kick tactics.
* Tactical screens for planning defensive and offensive formations.
* Player ageing and retirements - skill varies with age.
* Financial control of the club including loans, sponsorships and match advertising.
* Buy and sell players on the transfer market, and browse any club.
* Player contracts and renegotiations.
* Ground development for increasing crowd capacity.
* On screen help system.
* Editor for creating custom scenarios with registered version.
REQUIREMENTS
* 68030 or later, 68040 recommended, an FPU is NOT required.
* 3.7MB free RAM - on older Macs with 8 bit colour.
* 5.0MB free RAM - on newer Macs with 16 bit colour.
* 640x480 at 256 colour screen
* OS7.1 or above - (OSX - I simply don't know)
DISTRIBUTION
This English League Manager demo may be freely included on CDROMs.
CONTACT
Malcolm:- [email protected]
http://www.kagi.com/mrj.mcquoid/default.html
http://www.tigabyte.freeserve.co.uk/default.html
TigaByte Software, 24th October 2001.
[Archived as /info-mac/game/english-league-manager-115.hqx; 1240 K]
Date: 29 Oct 2001
To:
Subject: [*] Glypha III 1.1b2J - Japanese Version
This is the Japanese version of the public domain Glypha III package.
Ported To MacOS X by Mark Pazolli
Originally Developed By John Calhoun
Japanese Version by Bridge 1 Software
In Glypha III, you are placed inside an Egyptian temple with only your
lance and winged steed to aid you. Here you will be forced to do battle
with Sphinxes in order to gain the honor of a place on the High Scores
list.
This is the Mac OS X version of the classic arcade style game.
[Archived as /info-mac/game/arc/glypha-3-11b2-jp.hqx; 855 K]
Date: 30 Oct 2001
To:
Subject: [*] Haxial DiskCatalog 1.000
Haxial DiskCatalog is a utility for cataloging CDs, hard disks, folders,
and any other type of disk. It allows you to browse the contents of
disks without having to find them and insert them into your computer.
More importantly, you can search all of your disks at once (again without
having them in the computer), and DiskCatalog will display a list of all
the files found, and their location. When you're looking for a file and
you don't know where it is, this is much easier than manually searching
all your disks. DiskCatalog is designed to be very fast -- search
results usually appear instantly.
DiskCatalog is available for:
MacOS 9 or better (with CarbonLib 1.3.1+).
MacOS X (10).
Windows 95 or better.
The Product Page is here:
http://www.haxial.com/products/diskcatalog/
And the company website is:
[Archived as /info-mac/disk/haxial-disk-catalog-10.hqx; 324 K]
Date: 27 Oct 2001
To:
Subject: [*] Osaifu weekly1.0 Japanese
Osaifu weekly1.0
This is HyperCard stack for daily monay management. You can
calculate your purse "in-out" easily and record some notes
everyday. Easy operate and simple appearance with useful
"Status strings field" are just fit to your old PowerBook 1XX
serious 640 X 400 display. Anyway, you can try all the
functions, free!
System requirement: Macintosh with "Japanese" system and HyperCard
2.2J or later
[Archived as /info-mac/app/bus/osaifu-weekly-10.hqx; 24 K]
Date: 28 Oct 2001
To:
Subject: [*] RPN Calculator 1.4.4a 68K
RPN Calculator is a mathematically robust RPN implementation for Macintosh
in two flavors: PPC and Carbon. No more 68k builds are planned, but V1.44a
will remain available for 68k users. Note that 1.44a applies the same fix
to 1.44 that 1.46 applied to 1.45, and is therefore recommended for 68k
users. V1.46 is essentially a final quality program and is very reliable.
Its features include:
100 element stack
8 memories
Full support for complex number math
Scalable user interface
Statistics
Systems of equations (up to 5 equations and 5 unknowns)
Prime number search
Factorization
Prime factorization
Fraction approximation to decimal expansions
Base Conversion
Function library (up to 200 user-defined functions)
Constants (up to 200 user-defined constants)
Simple help system
[Archived as /info-mac/sci/calc/rpn-calculator-144a-68k.hqx; 750 K]
Date: 28 Oct 2001
To:
Subject: [*] RPN Calculator 1.4.6 Carbon
100 element stack
8 memories
Statistics
Prime number search
Factorization
Prime factorization
Base Conversion
Simple help system
[Archived as /info-mac/sci/calc/rpn-calculator-146-cbn.hqx; 1026 K]
Date: 28 Oct 2001
To:
Subject: [*] RPN Calculator 1.4.6 PPC
100 element stack
8 memories
Statistics
Prime number search
Factorization
Prime factorization
Base Conversion
Simple help system
[Archived as /info-mac/sci/calc/rpn-calculator-146-ppc.hqx; 894 K]
Date: Mon, 29 Oct 2001 21:00:00 -0800
To: [email protected], [email protected],
Subject: [*] TidBITS#603/29-Oct-01
After days of speculation about Apple's new non-Mac device, the
mystery was resolved as the iPod, a beautifully small MP3 audio
player that sets a new standard in its field. Jeff Carlson
contributes a hands-on review, and looks at the one thing that may
prevent the iPod from being the hit it deserves to be. Also in
this issue, Dan Kohn looks at why encryption won't protect online
revenue streams, and we note the release of Windows XP and
IPNetSentry 1.3.
Topics:
MailBITS/29-Oct-01
iPod Makes Music More Attractive
Steal This Essay 2: Why Encryption Doesn't Help
[Archived as /info-mac/per/tb/tidbits-603.etx; 31K]
Date: 27 Oct 2001
To:
Subject: [*] URL Manager Pro 3.0b18J - Japanese Version
This is the Japanese version of the URL Manager Pro package.
This development version of URL Manager Pro 3.0 runs on Mac OS X and Mac
OS 9 and higher with CarbonLib 1.1 or higher. Please check the Web Site
regularly for new updates.
"In the shareware arena, my pick is URL Manager" - Adam C. Engst
"You have got me addicted" - Henry Norr, San Francisco Chronicle
"A must have for serious Web users" - Tucows rating: 5 out of 5
"It's a polished, professional-standard application packed with useful
features, neat shortcuts and quality design. Brilliant." - MacFormat UK.
URL Manager Pro is a repository for your favorite Internet addresses or
URLs (Uniform Resource Locators). URL Manager Pro allows you to organize
and collect URLs in a hierarchical structure. Organizing bookmarks
between and within folders is easy with Drag & Drop. Drag HyperText
links from your Web Browser to the URL Manager Pro window to add a URL
to the repository. To go to a URL, Drag & Drop a bookmark to the window
of a Web Browser or double click.
URL Manager Pro adds tight integration with Navigator, Explorer, iCab,
Anarchie, Fetch, NetFinder, Claris Emailer, Outlook Express and Eudora.
With URL Manager Pro you can add bookmark menus to the menu bar of these
applications. Also, URL Manager Pro adds the URL Manager shared icon
menu to the menu bar. With this menu you can create bookmarks for Web
Pages from --within-- Navigator, Explorer, iCab, Add Notes, Grab All
URLs on a Web Page or in an E-Mail message, and explore the Internet
with a predefined set of Search Engines.
[Archived as /info-mac/comm/inet/web/url-manager-pro-30b18-jp.hqx; 1210 K]
Date: 27 Oct 2001
To:
Subject: [*] VersionLoader 1.0a2 (MacOS X version)
* VersionLoader is a Client application for the VersionTracker
(http://www.versiontracker.com) database to keep the overview of what is
new - comparable to the Apple Software Download Agent.
* System requirements: MacOS X 10.1 (requires "curl" shell command)
Disclaimer:
This release is an experiment (or demo) to show core functionality. This
release is Freeware but the right to change this for future releases is
reserved.
Any and all trademarks mentioned belong to their respective owners. They
are used in this document only for reference/descriptive purposes.
[Archived as /info-mac/app/version-loader-10a2.hqx; 1740 K]
Date: Sat, 27 Oct 2001 11:54:54 -0400
Subject: adapter for small power plug
Anyone know of an adapter that would allow you to use an older power
adapter with the newer iBooks and TiBooks? I believe the voltages are
the same. It is just the size of the plug that has changed.
It would be simple to make one if I know where to buy those connectors.
Amy help would be appreciated.
John Tierney
[email protected]
Date: Mon, 29 Oct 2001 14:50:06 +0200
Subject: DVD region fixer
Hi All,
Anyone know of a way to be able to watch DVDs with the Apple DVD
Player without the restrictions of only being able to switch between
regions 4 times? I know this kind of thing exists on Windoze (DVD
Genie which resets the number).
The other option, as I understand it, is to have 2 different programs
to play DVDs- one set to one region and the second for the other. If
that is a solution, can anyone recommend a good second DVD player
other than Apple's?
Much TIA,
E. Blasberg
Date: Mon, 29 Oct 2001 22:29:05 -0600
To: "Info-Mac List"
Subject: Extensions Mgr: Error -116 on save Missing Extensions
Ever since 9.0, whenever Extensions Manager says there are missing
extensions and tries to save a list of them, I get an error -116
(Size Check Failed). The Missing Extensions text file appears, but
it is always empty. I upgraded to 9.0.4, 9.1, and now 9.2.1, all
with consistent behavior.
I've tried deleting Extensions Manager's prefs file with no results.
And of course I've run Disk Warrior and Tech Tool Pro from time to
time, also without results. Any ideas what's wrong and how I can fix
it?
Date: Sun, 28 Oct 2001 14:58:06 +1100
Subject: Mac avi players
Is there a shareware or freeware avi player for the mac?
I keep getting friends e-mails with avi attachments and usually I can
get sound but no pikkies with QT 5. Any suggestions?
Cheers Glen
Dr Glen Hawkins
Sydney, Australia
[email protected]
Ph: +61407700701
Fax: +61407701717
Date: Fri, 26 Oct 2001 14:03:49 -0500
Subject: Old Afga Slidewriter
I mispoke in the last issue, What I have is Afga Slidewriter with
"conductor software" I believe it is the same as POM. I used to run
an old Afga Slidewriter off an old mac until the Harddisk crashed
for good. I went to the original disks and manual, but the the disks
were toasted by placing them on a speaker in storage. I tried fixing
the disks but no avail and even tried canopener to see if I could
recognize files, but the disks are all just garbage. I have been
able to replace the application, but I still need the system files,
specifically the film LUT tables and any other files that would be in
the system file. Afga is of no help, since they no longer support
film recorders, and the place they refer me to wants big bucks for a
postscript rip. I dont need to image postscript files, just plain
bitmap Picts. Can anyone out there help me and my art students? I
can prove I have the original disks, so there is no copyright issue
being violated, Afga has just washed their hands of the whole
business.
Thanks
Bill Hubschmitt
Art Dept
Eastern Illinois Univ.
[email protected]
Date: Fri, 26 Oct 2001 21:06:53 -0400
To: InfoMac posting
Subject: pc card problem
I have a PB 1400 that recently developed a problem. It refuses to link to
any other computers or the router on my Ethernet network. I bought a new
PCMCIA ethernet card (Asante10mb card) and that doesn't work either. The
original card was a Dayna Communicard plus. The computer recognizes the card
when its software is loaded, the link light lights, and the data light
flashes, but no other computers show up nor can the PowerBook be seen by
any other computer.
The PowerBook has system 8.6, and 32 megs of ram, the other computers have
sys 8.6, 9.04 and 9.2. Any clues or suggestions? I've tried the usual fixes,
clean install, Norton disk utilities, techtool pro, disk first aid, etc. all
show no problem. I tried the cards in another 1400, also no good.
TIA
John
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
Date: Sun, 28 Oct 2001 20:44:42 +0000
Subject: software for USB pci card?
In article ,
[email protected] (The Info-Mac Moderators) wrote:
> Date: Wed, 24 Oct 2001 14:55:48 +0100
> From: Ezra Nathan
> To: Info-Mac digest
> I have bought a Belkin 2 port USB pci card for a 333Mhz G3 desktop in order
> to have a laserwriter with a USB connection work off of it. The G3 is
> running OS 8.5. Do I need to install any software to make the card work? Has
> anyone any experience with doing something like what I am about to do and
> care to give any advice.
> Thanks,
> > Ezra
Yes, you require the USB driver. There is a difference for pre 8.6 and OS
8.6Have a look at...
http://download.info.apple.com/Apple_Su ... B_Updates/
Lobo.
This email IS valid... [email protected]
Date: Fri, 26 Oct 2001 23:29:48 +0300
To:
Subject: Software Update Crashes
I'm using a PowerPC 9600/MacOS 9.1 and and a G4 Cube/MacOS 9.2. Every time
I use Software Update on both these computers, the first file is downloaded
then installed and then the Software Update hangs/crashes the computer which
has to be hard-reset. Does this even with clean System installs. Can
anyone explain what the problem is?
--Info-Mac-Digest--
