Compact Pro F-1.51 (French)
Download: http://archive.info-mac.org/cmp/compact-pro-151-fr.hqx
French language version of Compact Pro. Compact Pro is a shareware
file compression and archival utility. It compresses and stores files
in "archives" which may span multiple diskettes. Compact Pro supports
data encryption (US and Canadian users only) and self-extracting
archives. Version F-1.51 is a "fat" binary, so it will run in native
mode on Power Macs as well as on standard Macs.
Compact Pro may be used on a free trial basis for 30 days. If you
find it useful and continue to use it beyond the free trial period,
you are required to pay a $25 registration fee. Self-extracting
archives created by Compact Pro may be used for commercial
distribution of software/data with no additional license fee.
This file is a self-extracting archive created with Compact Pro.
Double-clicking on it will create a folder with the Compact Pro
application and documentation files.
Bill Goodman
Cyclos
