DiskExpander 1.2
DiskExpander 1.2
Download: http://archive.info-mac.org/cmp/alysis- ... der-12.hqx
Here is Alysis' Disk Expander version 1.2 downloaded from the
Alysis Vendor area on Compuserve. from the Read Me file:
The Disk Expander is a system extension. Adding it to your Macintosh
System Folder will allow you to read and use files and applications
that have been compressed by More Disk Space. You will find that
applications are much smaller in compressed form and that they require
no extra time to launch. Compressed applications and compressed
document files behave exactly as you would expect them to. Even
multi-megabyte files will open without delay and without any disk
space overhead.
