Subject: Info-Mac Digest V17 #100
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Mon, 19 Jun 00 Volume 17 : Issue 100
(A) found free ftp server for the Mac
3d ftp search i. project X hot Sauce
can't get scanner to work with ibook
iMac hesitation?
iMac hesitation?
Info-Mac Digest V17 #97
problem downloading software
from the new address.
and Chris Pepper.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V17 #100"
Date: Sun, 18 Jun 2000 19:49:26 -0300
To:
Subject:
This is a multi-part message in MIME format.
------=_NextPart_000_000D_01BFD95E.4F05DA00
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
We have used apple talk for years and it has work fine. Now we have a =
canon copier/fax/printer. The canon has apple talk software in it .the =
trouble is that it need a rj45 plug. I try cutting the 8 min din off the =
apple net phone box to add a rj45 plug but the pinout is not the same as =
the Mac serial port. Need help. Anyone.
bobwaz.
Content-Type: text/html;
We have used apple talk for years and it has =
work=20
fine. Now we have a canon copier/fax/printer. The canon has apple talk =
software in it .the trouble is that it need a rj45 plug. I try cutting =
the 8=20
min din off the apple net phone box to add a rj45 plug but the pinout =
is not=20
the same as the Mac serial port. Need help.=20
Anyone.bobwaz.
------=_NextPart_000_000D_01BFD95E.4F05DA00--
Date: Fri, 16 Jun 2000 18:21:33 -0400
To: [email protected]
Subject: (A) found free ftp server for the Mac
Dear Digest readers,
Well the answer to my question came from an unlikely source!
NCSA-Telnet has the most wonderful easter egg. Go to the Edit menu,
select preferences, and one of the submenu items is FTP Server. You
then edit the preferences to set up your Mac as an ftp server.
Completely free, and speaks standard Unix FTP commands. And here all
the time I thought all NCSA Telnet was, was an ftp client and telnet
client. One of the oldest Mac applications happens to still work
under MacOS 9.0.4 as something I never thought it could do.
Sincerely,
[email protected]
Check out over 800 internet sites updated monthly at:
http://www.index-site.com
Date: Sat, 17 Jun 2000 16:38:10 -0400
To: "Infomac To Digest Reply" ,
Subject: 3d ftp search i. project X hot Sauce
quoting The Info-Mac Network and possibly previous message abstract:
>hi - I'm trying to find a file that would've been on the archive about 5
>years ago, but has disspeared... It was some 3d ftp program with a 68k and
>ppc version. I've searched the info-mac archive, but found nothing. I've
>searched via alta-vista, but nothing came up via that either.
>Does anyone know where this program is stored???
Current location
Now Defunct ----- Apple Project X Read Me
Contents
System Requirements
Installation
Quick Start Instructions
Incompatibilities & other issues
Feedback!!
System Requirements
This version of Project X requires a PowerPC-based Mac OS computer, or a
68K Mac OS based computer with a floating point unit, one megabyte of RAM
and Netscape Navigator version 1.1 or later.
Installation
The folder called "Project X Data Files" can reside in the preferences
folder or in the Project X application folder. If the data files are
missing from one of these locations, the X space will be empty.
If you are having problems installing or getting started, please send us
a bug report through our Bug Form online at
http://mcf.research.apple.com/ProjectX/feeback.html. We will get back to
you as soon as possible.
For the user manual, please refer to
http://mcf.research.apple.com/ProjectX/.
Incompatibilities & Other Issues
Project X cannot access compressed data files. If you use DiskDoubler,
or a similar application, please make sure that the data files will not
be compressed.
If you move or rename the Project X data files, the X-space will appear
empty. If this occurs, return the Project X Data Files folder to its
original position or rename the files.
Project X is a technology prototype from Apple. As such, it has not been
rigorously tested. If you experience a problem with Project X, please
contact us through the Project X website at
http://mcf.research.apple.com/ProjectX/feedback.html
We want your feedback! After using Project X, please remember to tell us
what you think. A feedback form can be found at
http://mcf.research.apple.com/ProjectX/feedback.html.
Thank you for experimenting with Project X!
______ End of readme
Hope you have fun but the project was not ftp but http linked metacontent
file I believe. Good luck
>>>-----------Reach me by ICQ# 7162477------------------~~~
Date: Sat, 17 Jun 2000 10:23:09 -0400
Subject: can't get scanner to work with ibook
i have an ibook 0s9 tried to hook up my umax astra 1220 scanner , i
downloaded the vistascan 3.5.1 software and everytime i start up computer it
crashes with this software.
problem is i need to get this scanner to work in order to daisy chain my zip
drive (to the scanner and the scanner to the ibook) because they are not usb
products
i am using a microteck adapter to convert these into usb
does this mean i have to go out and buy a new scanner and zip drive
sue
Date: Sat, 17 Jun 2000 09:10:22 -0400
Subject: iMac hesitation?
At 11:16 PM -0400 15/6/00, "Quattlebaum.Bill" wrote:
>I work at a research facility that has well over 100 1st and 2nd generations
>iMacs. The majority of them are running OS 9.0.4 but some still have 8.6.
>Regardless of the OS or the RAM (all have enough real RAM to not run Virtual
>memory) most of them share an irritating problem:
>Frequently the iMac will stop responding - the seconds on the clock display
>will freeze. But in about 10-30 seconds it start running just fine again. If
>you wee typing in MS Word the keystrokes are ignored until it unfreezes. If
>you were in the Finder clicking a folder it does not open until the thaw.
I started seeing this type of behavior (and even longer stalls) on my
Power Computing machine after I hooked a Jaz drive into the SCSI
chain. It seems to have something to do with the drive spinning up
but no bets here. Do you have Zip or Jaz drives somewhere in the
setup? If I remember correctly, I've seen this on all OS 8.x
versions I've used.
Ken Laskey
[email protected]
Date: Sat, 17 Jun 2000 16:38:14 -0400
>Not just iMacs, Bill, I have been noticing the same kind of
>misbehaviour with my beige G3 266 since upgrading from OS8.5.5 to
>OS9.0.4.
>I wondered whether it was something to do with Sherlock busily
>updating its index, but I actually wouldn't have a clue.
I seem to recall an auto DiskFirdt Aid Check on startup as an
configurable option in DFA's preferrences. I haven't used 9 yet (just
8.6) though you might wnat to check out MacFix-it's advice.
Then again the following may be correct
>I had experienced similar indications and found the problem to be with a
>new implementation of the DHCP Client. I suggest you go to Apple's Tech
>Info Library and just enter search for DHCP
>and read the first couple of articles that show up. Hope this helps!
remember that iDisk may require its DHCP client services
Date: Fri, 16 Jun 2000 12:25:23 -0400
Subject: Info-Mac Digest V17 #97
In article , [email protected] wrote:
> Subject: Videoconferencing Software
Just got the Logitech QuickCam VC USB to install on an iMAC (slot loading,
350 MHz)
The bundled CU-seeME software does not work on this model, and upgrade is
only available at full price. One can download the free Cornell University
version of CU-seeME, which does work but is more limited in features.
Date: Mon, 19 Jun 2000 16:22:00 -0300
Subject: problem downloading software
Dear list members,
I have a problem downloading software from the info-mac archive and others.
When I try to open some program I downloaded and decompressed with Stuffit,
I get an error message -39, and sometimes error message -199.
I am using an iMac with OS 8.5.1, and Netscape Communicator 4.6
Your help will be appreciated.
Yours,
F. Cukierman
--Info-Mac-Digest--
