Info-Mac Digest V16 #385
Subject: Info-Mac Digest V16 #385
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Fri, 17 Dec 99 Volume 16 : Issue 385
[*] Smart Scroll 3.6b6J - Japanese Version
[*] AppearanceHopper 1.9 Fr
[*] CD File 99 Fr
[*] Itivuttaka--Sayings of the Buddha
[*] KanjiCPreProcessor 1.2
[*] Polish Adjectives 1.0.3 - foreign language learning
[*] WolfEdit 2.0.4 1st/2nd Encounter Patch
AVI to QT problems
BIG ICONS
Help!!! Need scanner driver
how to configur different Internet-connections
iMacs
iMovie problem
Info-Mac Digest V16 #384
LCII set-up for email
Powerbook 100 sadmac problem
USB-Serial adapter for G4 & HP LaserJet4MP
Using icons.
from the new address.
Tom Coradeschi, Shawn Bunn, Christopher Li, Patrik Montgomery, and
Ed Chambers.
The Info-Mac Digest is sponsored in part by AOL who is
responsible for our having the main Info-Mac machine .
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #385"
Date: 17 Dec 1999
Subject: [*] Smart Scroll 3.6b6J - Japanese Version
This is the Japanese version of the Smart Scroll package.
Smart Scroll enhances scrollbars for most apps, including Netscape,
Emailer, Eudora, ClarisWorks... (Mac OS 8.5, 8.6, & 9.0) only enhance the
Finder's scrollbars)
Proportional Thumbs: The size of the thumb relative to the scrollbar
shows how much of a document is displayed in a window!
Live Scrolling moves the window contents while you drag the thumb. Power
up your scroll bars!
Scrolling Speed may now be adjusted for all scroll bars and menus!
*New!* Scrolling Speed may be adjusted to your preference. If your
windows are too fast for your taste, this will let you set a comfortable
scrolling speed. The setting is applied whenever you click in a
scrollbar and hold the button down, but full speed is available at any
time by clicking repeatedly instead.
*New!* This feature controls Menu Scrolling too! Keep the cursor pinned
to the edge of the screen (above or below the menu) for full speed, or
bring it in a few pixels to slow down the scrolling to the rate selected
in the Smart Scroll control panel.
This control panel works on any Mac introduced since 1990, running
System 7.0 through Mac OS 9.0.
New in version 3.6:
*Scrolling Speed may now be adjusted for all scrollbars, as well as menus
*Support for Mac OS 9.0
*Many internal changes and fixes
Mac OS 8.5 and later provide applications with the possibility of
displaying proportional thumbs, but applications will need to be updated
to take advantage of the new feature. Among applications included with
Mac OS, so far only the Finder and a couple others uses this feature.
Smart Scroll provides proportional thumbs for "the rest of apps" today,
without updating applications applications such as Netscape, Emailer,
AppleWorks, Word or system add-ons such as control panels!
Smart Scroll communicates with Kaleidoscope so scrollbars using the new
color schemes can be proportional and have active scrolling!
[Archived as /info-mac/gui/smart-scroll-36b6-jp.hqx; 178 K]
Date: 16 Dec 1999
Subject: [*] AppearanceHopper 1.9 Fr
AppearanceHopper comble des trous dans la personnalisation de MacOS,
en vous donnant accès à des options non activables depuis le tableau
de bord Apparence. Avec AppearanceHopper, vous pouvez : régler la
police et le corps de chaque entrée de la liste des polices Système,
ainsi que le style utilisé pour les en-têtes des petites polices
Système; accès au options "cachées" des barres de défillement;
choisir le style des noms d'alias, désactiver la flèche sur les
alias; et modifer la palette du sélecteur d'application, le tout dans
un tableau de bord simple d'emploi.
AppearanceHopper est un shareware à $9 disponible en anglais,en
français, et en suédois; après dix essais, vous devez enregistrer le
logiciel pour pouvoir continuer à l'utiliser. Mac OS 8.6 ou ultérieur
et AppleScript sont nécessaires. AppearanceHopper a été testé avec
MacOS 8.6 et MacOS 9.
Pour plus d'informations, visitez le site web de Weedhopper Press à :
http://www.whpress.com/fr/
[Archived as /info-mac/gui/appearnce-hopper-19-fr.hqx; 1255 K]
Date: 16 Dec 1999
Subject: [*] CD File 99 Fr
CD File, la nouvelle gestion de discothèque autonome au design
irréprochable. Look iMac. Toutes fonctions utiles incluses, sauf gadgets.
En Français.
CD File, the new Hi-Tech CD database. Look iMac. With runtime. All
functions. No gadgets. In French.
CD File 2.0 (Mac/PC) - Shemes Kaleidoscope (Mac)
Belles images - Téléchargement MacPix (Mac)
http://cd.file.free.fr/indexfr.html
http://www.geocities.com/Paris/Salon/9990/indexfr.html
[Archived as /info-mac/data/cd-file-99-fr.hqx; 4119 K]
Date: 16 Dec 1999
Subject: [*] Itivuttaka--Sayings of the Buddha
The Itivuttaka is a collection of 112 short sutras from the Pali Canon in
mixed prose and verse, covering a wide range of the Buddha's teachings in
a form that is accessible, appealing, and concise. This application
randomly generates one of the verses each time it is opened, making it a
nice addition to the Startup Items folder. Additionally, clicking on the
quotation will generate a new verse. The verses can be saved as text
files, and printed from the "File" menu. If you encounter any unfamiliar
terms, there is a "Useful Definitions" item under the Apple Menu.
This application is offered as a free gift of Dharma.
May all beings attain Perfect Peace.
Brian Kelley
mailto:[email protected]
CompleatMac Software
http://home.nycap.rr.com/compleatmac/
[Archived as /info-mac/app/itivuttaka.hqx; 891 K]
Date: 16 Dec 1999
Subject: [*] KanjiCPreProcessor 1.2
KanjiCPreProcessor:
Japanese Shift-JIS C/C++/Rez pre-processor - free source code
KanjiCPreProcessor.c is the source code of a basic filter for C, C++, and
Rez source files, which strips all the comments, and replaces in strings
all the
Shift-JIS double-byte characters whose second byte happens to be a
backslash with their equivalent octal escape sequences, so that the source
files can be successfully compiled even when the compiler is not truly
multibyte-savvy, or when the Japanese script is not supported by the system
the compiler is running on...
Note: This code has been successfully compiled with CodeWarrior Discovery
Programming Edition 4, using the following project stationery:
MacOS : C_C++ : Standard Console : Std C Console 68K
In addition, "ANSI strict" must be explicitly turned *off* in the C/C++
Language Settings Panel.
Disclaimer: This source code is provided "as is" and is free for you to
use, at your own risk. Please let me know of any bugs or suggestions for
improvements.
--Michel MARIANI (a.k.a. Mikaeru)
Mikaeru Software:
[Archived as /info-mac/dev/src/kanji-c-preprocessor-c.hqx; 6 K]
Date: 16 Dec 1999
Subject: [*] Polish Adjectives 1.0.3 - foreign language learning
'Polish Adjectives' helps Macintosh users to learn and practise declension
and comparison of adjectives. You can use it for looking words up and
practising vocabulary. The module already contains more than 9,000 Polish
adjectives, with English translations (partially). You can add extra
adjectives, and change or delete the existing entries to suit your own
needs. You can create special groups of adjectives for practising on
(ready made groups include colors, shapes, and much more). The unregistered
version has limitations. To use the module you need to have the parent
program 'Verbs & Nouns' available from the Info-Mac mirror sites.
To get more information please visit:
http://users.netmatters.co.uk/dandaforbes
Jacek Iwanski.
[Archived as /info-mac/edu/lang/polish-adjectives-10.hqx; 1186 K]
Date: 16 Dec 1999
Subject: [*] WolfEdit 2.0.4 1st/2nd Encounter Patch
This is a patch for WolfEdit 2 to enable the creation
of scenarios that can be played with the 1st or 2nd
Encounter versions of Wolfenstein 3D. Full instructions
are included.
WolfEdit 2 can be downloaded from the Info-Mac Archive.
To install the patch, you will need ResEdit, which can
be downloaded from Apple's web site.
What is WolfEdit 2?
WolfEdit 2 is a complete scenario editor for the
Macintosh version of Wolfenstein 3D. With WolfEdit 2,
not only can you design your own maps, you can replace
the artwork for walls, doors, objects, weapons and
more.
Greg Ewing
http://www.cosc.canterbury.ac.nz/~greg
[Archived as /info-mac/game/com/wolf/wolf-edit-1e-2e-patch.hqx; 14 K]
Date: Wed, 15 Dec 1999 11:51:04 -0800
Subject: AVI to QT problems
I can download an avi file with QuickTime. It plays until it completes
downloading. Then suddenly the picture is gone (white screen) but I
still have sound. Any suggestions? MacOS 8.6. QT 4.03. Netscape
4.7. Thanks.
Date: Wed, 15 Dec 1999 23:17:08 -0700
Subject: BIG ICONS
Thanks to all who helped me with this. I feel like an idiot. I am always worried about the "high end" mods in the newest OS that I overlook the simple stuff.
Thanks again and Happy Holidays
da\/e
Date: Wed, 15 Dec 1999 13:45:01 -0500
Subject: Help!!! Need scanner driver
Have you tried the HP web site(www.hp.com)? If they are not there they
don't exist. I kinda doubt that ther are any.
Jeff
> I have an HP PhotoSmart S20 scanner - the kind that does 35mm slides.
I
> can't find Mac USB drivers for it. I've been using it under Virtual
PC, but
> wouold love to use it natively.
Date: Thu, 16 Dec 1999 00:15:17 +0100
Subject: how to configur different Internet-connections
Hello,
Is there any shareware, freeware to configure easily several
Internet-connections, with different TCP/IP ?
Thanks
Dirk
Date: Fri, 17 Dec 1999 09:54:34 -0600
Subject: iMacs
I just got back from a business to trip to Paris and was delighted to=20
see that several boutiques along the Avenue des Champs =C9lys=E9es had=20
iMacs displayed.
What popped my o-rings was that in some of the stores the iMacs were=20
used as chic props in the displays. Not as computers, mind you, but=20
as trendy objets d'art, suspended at odd angles to highlight other=20
merchandise.
Now doesn't that just encapsulate the genius of Apple's=20
morphogenesis? Can you imagine doing this any other computer?
Sqwak away, critics, you will help make Apple better, but you just=20
gotta love the vision thing.
Robert P. Lenk, PhD.
Inspired Therapies(TM) for the Next Century
Date: Wed, 15 Dec 1999 14:49:20 -0500
Subject: iMovie problem
I have a new iMac SE with iMovie. I had this problem with version 1.0 and
now with 1.0.1.
If I am capturing DV that includes the sounds of a water fall, or waves
crashing the sound gets clipped and distorted both on the iMac and when I
Print to Video.
This occurs with at least two different scenes on two different mini-dv
tapes.
I have tested the following:
Loaded iMovie onto my G4 tower with the same sound clipping and distortion.
This shows the iMac is not at fault.
Using Final Cut Pro 1.0.1 on the G4 give perfect sound quality. This is
important because it shows the camcorder and the firewire cable are not at
fault.
Has anyone seen this? I am also trying to get through to Apple since this
should be covered in the 90-day tech support.
thanks,
bill qb quattlebaum
NIEHS
Date: Thu, 16 Dec 1999 08:38:52 -0600
Subject: Info-Mac Digest V16 #384
[email protected] writes:
>> Why would I wish to make a visible file invisible, or vice versa?
>> The most obvious reason seems to be to provide an additional level of
>> security. Would an invisible file appear in dialogs?
>Well, security (hiding a file) might be one reason. Of course, you would
>need to remember where you put it, so you could later make it visible.
Actually, there is a way in the find-file dialogue box of finding files
with an invisible attribute. I am still using 7.5.x, so I am not sure if
it still works with Sherlock, but the method is to hold down the option
key while selecting other things to look for. You will get more choices,
one of which is the visibility attribute. Check invisible and it will give
you all the invisible files on the volume, etc.
Date: Thu, 16 Dec 1999 11:57:05 +0000
Subject: LCII set-up for email
My girlfriend has an LCII which she can't as yet afford to replace. She
would, however, like to be able to use it for email at least.
Is it too old a machine to do this effectively? If not, which
hardware/software is the most appropriate for a machine of this vintage?
TIA
Simon
Date: Fri, 17 Dec 1999 11:44:21 +0100
Subject: Powerbook 100 sadmac problem
hi!
all of the sudden my good old trusty powerbook 100
refuses to boot and presents a Sad Mac error:
0000000F
00000002
has anybody any idea what this means?
more information:
troubles began, as saving onto the internal drive gave
me i/o errors (error -36)
i then connected the pb100 to my desktop (660av)
backuped the drive's contents
reformattet the pb100 drive
copied all files from the backup to it
then, suddenly the pb100 refused to boot with the above sadmac error
booting from an external floppy does not work (same sadmac error)
connecting the pb100 to the desktop still works
which would indicate that the harddrive itself seems to be o.k.
since then i've tried to find & understand the Sad Mac error codes
but with no real success
i.e.: most lists quote "0000000F" as "reserved for macintosh compatibility"
whatever this is supposed to mean...
TIA for any help
cheers,
muki
muki pakesch mailto:[email protected] http://www.t0.or.at/~mpakesch
Date: Wed, 15 Dec 1999 17:28:42 -0800 (PST)
Subject: USB-Serial adapter for G4 & HP LaserJet4MP
Hello,
We have a G4 running OS 8.6 and an old HP LaserJet
4MP.
We bought an Entraga USB-serial adapter but found out
that didn't support Geoport, Midi or AppleTalk
(LocalTalk) networking. Our printer didn't work.
The Keyspan US-serial adapters don't support HP
laserjets.
With our old mac, we were able to plug in the PC and
the mac and the printer was peacefully shared.
Now we can only print from the PC. Our PC "friends"
are laughing.
Does any one know what we need to do to make our HP
laserjet 4MP print?
Thank you.
Phil
__________________________________________________
Do You Yahoo!?
Thousands of Stores. Millions of Products. All in one place.
Yahoo! Shopping: http://shopping.yahoo.com
Date: Wed, 15 Dec 1999 14:33:33 EST
Subject: Using icons.
>From: JIM BRUNSWICK
>Subject: making my own icons
It is easy to install icons. First select and copy the icon you want to
install. Then, do a getinfo of the file you want to install the icon onto.
Then select the icon in the upper left, and paste.
Be aware that "custom" icons do not have all the properties of the originals,
at least without a bit of resedit support.
And icons cannot be of arbitrary size...
Michael B. Luskin
--Info-Mac-Digest--
