Subject: Info-Mac Digest V16 #363
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Sat, 13 Nov 99 Volume 16 : Issue 363
(C) Data Detectors.
[Q] how to set up a Headless Mac
Bad Apple experience
COPERNIC
DarkSide screen saver for the Mac
IDE Hard Drives in beige G3
PB infrared and system clock changes after upgrading to system9
VirtualPC-Windows95 or 98?
why a 30 second delay sending e-mail?
containing gigabytes of freely distributable Macintosh software.
the Subject line.
the Subject line.
form at before contacting us.
Info-Mac volunteers include Adam C. Engst, Demitri Muna, Hugh Lewis, Tom
Coradeschi, Shawn Bunn, Christopher Li, Patrik Montgomery, and Ed Chambers.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #363"
Date: Sat, 13 Nov 1999 10:18:52 -0700
Subject:
I wrote on Nov 3 this query...I received at least 60 replies to my question
from all over the planet...Most had some very useful obervation and four
had the identical solution that I had found on my own by playing around
with the Toast software that I had missed the first few times around... All
of the letters had ways to make the problem diminish and many had
interesting software solutions that I had not encountered before. They are
all very much appreciated.
I have been stymied by the inability to make a compatible CD-rom of jpeg
files to be accessible from either a Mac or a Windows machine. I burned
the disks using Toast with the ISO 9660 file format and found that they
were fine for the Mac but with a Windows machine there did not appear to be
the jpg suffix required for the software to identify and open the files.
It was necessary to copy them over to the Hard Drive and then add the
suffix for some reason. Can anyone shed some light on this? I am in a bit
of a bind to get the solution to this pronto as I must produce a number of
disks this month. Is there another way to accomplish this compatibility
using Toast? Please contact me directly with advice on this issue as I
need a rapid reply if possible. Thanks in advance to anyone with a
solution!!!! [email protected]
Regarding my inability to produce a universally readable CD with jpeg
images using Toast...problem solved! I found that there were options in
Toast that I had missed as they are hidden under the data attribute which
does not have to be accessed in general usage of the software. Within that
are options to select for MS_DOS only, Windows Joliet and Mac as well as
translations from one to another in terms of file naming. One can also
choose as I did the option of all the file name extensions so that any and
all machines can access the files by seeing only the file naming convention
suitable to the OS in use. This works well. Further to that I found that
using ISO 9660 so that the CD would be Windows compatible set up as the
default the open file format available with ISO. This is a distinct
problem for older drives that will not read the open format. This is the
case with many 2X speed readers. There is another option in the ISO 9660
format which is not the default CD-XA but instead one should choose CD-ROM.
In this way one gets a closed and fully compatible CD for pretty much any
PeeCee as well as Mac machine so long as all the filename attributes are
also installed at the same time. I wish to thank the dozens of people who
tried to help me with all kinds of great advice and software options for
renaming and so forth. Info-Mac really is a great resource of good
Internet Citizens. One of the last idealistic place on earth....
"Just three rusty strands of barbed wire from the North Pole"
-Neil Fiertel (1941 - ?)
"Time is a great teacher, but unfortunately it kills all its pupils."
- Hector Berlioz (1803-1869)
Professor Neil Fiertel
([email protected]) or ([email protected])
FAB-3-98
Department of Art and Design
University of Alberta
Edmonton, Alberta
Canada T6G-2C9
The content of all my correspondence is my own and does not reflect the
opinions the University of Alberta or the Department of Art and Design
Date: Fri, 12 Nov 1999 22:28:38 -0400
Subject: (C) Data Detectors.
> Date: 11 Nov 99 06:50:58 -0500
> From: "D. Scott Beach"
> >Date: Fri, 29 Oct 1999 19:26:19 -0700
> >From: "Dr. James K. Butler"
> >Subject: ADD
> >A little while back I posted some information about the Apple Data
> >Detectors (ADD). They consist of a control panel, an extension and
> >AppleScript. Most people have not heard about them, but they are a FREE
> >addition to the OS and they can be downloaded from the Apple site.
> Dr. Jim:
> I've been using them since they were first introduced and think they're
> great. They're particularly good for extending the life of older software.
> For instance, we use FirstClass 3.x at the publishing company where I work
> but it's not really an internet mail client; even with the addition of SMTP
> gateways. With ADD we can make it sort of act like a modern mail client in
> as much as we can make it URL aware.
> I'd like to see someone come up with a data detector module that would
> allow modem dialing from text containing phone numbers.
> - Scott
I have to follow this up and say that I got interested enough by
James Butler's praises of ADD to download them and try them out myself.
I have not regretted doing so; why Apple has abandoned this jewel is a
bizarre mystery. Who knows...
-jc
* -jc IS *NOW* [email protected]
* Home page: http://members.tripod.com/~afeldspar/index.html
* The home of >>Failed Pilots Playhouse
Subject: [Q] how to set up a Headless Mac
What I really mean is how to have a mac run without a monitor? I
have a IIsi that I want to run IPNetRouter and Timbukto and a Quadra
950 as a file server. Don't need monitors for those purposes once
you get them up & running.
I tried to bring up the IIsi w/o the monitor connected. Nothing.
So, I plugged the monitor in and rebooted. The system came up in the
black & white mode. Hmmmm, says he, what's the trick?
Like Blanch, I depend upon the kindness of others.
--Dwight Early
Date: Fri, 12 Nov 1999 14:41:34 -0500
Subject: Bad Apple experience
I've heard of similar experiences with "The Apple Store" from several
friends. The lesson here is if you buy Apple Products, don't buy them from
Apple. The usual sources - CompUSA, MacWarehouse, Mac Zone - have proven
track records that are more reliable.
Regards,
Rob
[email protected]
-----Original Message-----
Sent: Thursday, November 11, 1999 4:26 PM
GenevaI recently had an
appalling
experience with Apple Computer that has shaken up my loyalty
and
advocacy in that company. Friends will say I had always been
an Apple
junkie. My 128K Mac and first issue of MacWorld magazine
have remained
collectibles. And I've owned about every other model Apple
Computer has
ever made including the IIe and IIGS.
I placed an order online at the Apple Store for an iBook
laptop and
AirPort after seeing it at MacExpo in 7/99. This was going
to be my 4th
Apple laptop purchase only because the AirPort technology
was very
cool.
After a 3-month wait, the iBook arrived with no AirPort.
Strike One.
I had gotten an iBook with a screen that has a couple
defective screen
pixels, one that is stuck on RED and a couple inches from
the center of
the screen. Strike Two.
After placing my third call to Apple Customer Service asking
for a
return or replacement, they continued to say " SORRY", a LCD
screen
such as mine with two bad pixels is within their guidelines
as being
acceptable. They said, "we can't help you" and offered no
replacement
and no customer satisfaction. Strike Three.
As a digital-imaging specialist and consultant it hurts me
to say this
company has turned it's back on a loyal customer and will be
losing
another evangelist.
I hope this story gets to the higher-ups and they realize
this sort of
thing is really damaging to Apple's market place and that
Customer
Service should also really care about customer satisfaction.
Does Apple
realize they are trading the cost of an iBook for many, many
lost
future sales? Or is it that they don't care any more.
Beware of buying electronic products with LCD screens and
CCD sensors.
Manufacturers are slacking off on quality control and using
units that
are not 100% perfect. Two of my Nikon digital cameras had
defective
pixels and Nikon customer service replaced the components
under their
warranty policy.
BTW, don't ever order from the Apple Store. They have a NO
RETURNS -
ALL SALES FINAL policy!
Please forward this e-mail to the higher ups at Apple
Computer.
Thank you
Jook Leung http://360vr.com 201 894 5881 fax: 201 894
5882
360VR Photography * 44A Honeck Street * Englewood, NJ 07631
--- 360 Degree Panoramic Images for Virtual Tours ---
Date: Sat, 13 Nov 1999 11:12:48 -0500
Subject: COPERNIC
Hi to everyone,
I have stopped using Sherlock because it was too long to specify the setups
everytime. Copernic Plus is great and there are new 2000 versions
available. Microsoft have an eye on the product or already bought it. Louis
Dear Copernic User,
It is with great pride that I am announcing the introduction of
the latest version of our leading search tool: Copernic 2000.
Starting now, our award winning Internet search tool will be
available in three versions: Copernic 2000, Copernic 2000 Plus,
and Copernic 2000 Pro.
Copernic 2000 now provides the means to target searches on 55
search engines grouped into 6 categories, while Copernic 2000
Plus features 32 categories with more than 255 search engines.
The completely new Copernic 2000 Pro version is the best solution
to searching the Web for information. It is perfectly suited to
those who require the ultimate search tool.
Have you ever dreamed of a tool that is powerful enough to allow
you to program your searches so that they are updated, for
example, on a daily basis, while you are asleep?
What would you say if, in addition, it were possible to receive
e-mail, first thing in the morning, providing a report on new
documents targeting your specific information needs? Well, all
that has become a reality, thanks to Copernic 2000 Pro.
This professional tool also allows you to automate operations
such as validation of results, downloading of documents, and
refining searches. Moreover, a spell-checker is now integrated,
making your search experiences even more effective.
Copernic 2000 Pro, the ultimate search tool, is available at the
following address:
=> http://www.copernic.com/buy.html
To upgrade your current version of Copernic 99 or Copernic 99
Plus, please read the instructions posted on our Web site at:
=> http://www.copernic.com/upgrade.html
For more general information on Copernic 2000, consult our home
page at:
Sincerely,
Andrew Ray
Copernic Technologies Inc.
P.S. Thank you for using our products!
ABOUT THIS E-MAIL
This e-mail was sent exclusively to our users who indicated -
during the installation of Copernic- a preference to receive
notification of product news, updates and special offers from
Copernic Technologies.
Please do not respond to this message. This is a post-only
mailing. Mail sent to this address cannot be answered. Instead,
visit:
http://www.copernic.com/contact.html
If you do not want to receive future announcements, please
unsubscribe by visiting:
http://www.copernic.com/unsub/
Louis Bergeron C.P. 68 Granby J2G 8E2
Bureau principal-Main office (450) 776-1074 Fax (450) 776-1113
Bureau secondaire-Secondary office (450) 372-6614 #172
E-mail [email protected]
Date: Fri, 12 Nov 1999 15:38:24 -0500
Subject: DarkSide screen saver for the Mac
I noted your list posting about "After Dark no longer?" I would suggest you
look into "Darkside of the Mac" screensaver shareware.
To quote from the manual: "DarkSide is a Macintosh application, and as such
should be easy to use without documentation. It also contains full balloon
help. However, complete documentation is available via the web at
. In addition, this web site always contains the
latest version of DarkSide, a list of frequently asked questions (FAQ)
about DarkSide, and other useful information."
DarkSide will run After Dark screen savers.
I don't know about OS9, but it has worked fine for all my system variations
through OS 8.6 on a beige G3.
Regards,
Bill
Date: Sat, 13 Nov 1999 09:18:30 +1100
Subject: IDE Hard Drives in beige G3
I would like to add a second HD to my G3/233 beige desktop (thinking of a
Quantum KA 13.6GB, 7200rpm) and the material around is confusing.
I appear to have a 'Rev B' machine which is capable of supporting more than
one IDE HD.(Beige G3/233 desktop with WD 4GB HD and PCI slot $F1
ATY,mach64_3DUPro video capability). There is no Zipdrive in the machine
and I believe these Zips are ATAPI coming off ATA1 Bus as does the CDROM.
The G3 workshop manual is also no help. It says the G3 has a SCSI CDROM
(whereas System Profiler tells me that Internal ATA0 ID=0 has the WD 4GB
and ATA1 ID=0 has the CDROM!)
There is a 'spare' 40pin 'IDE'-type cable which exits the mother board next
to the existing HD exit cable.There is also a 4-pin 'HD-like' power lead
ready for 'something'. Guess the mounting for another HD is above the Zip
bay since there are 'rails' there to accept a 'sled'.
I have seen info which indicates 'master-slave' etc but this is (I thought)
for HDs which are connected to the same IDE cable (?) If there are 2 HD
controllers on the mother board and this 'extra' cable is for a second HD
then should it be jumpered as 'Master' also?
The question is are these cables for a Zip or for a second HD? Has anybody
fitted a second IDE HD? If so how? Would a 7200rpm HD overload the psu?
tony
Date: Sat, 13 Nov 1999 09:48:04 -0800
Subject: PB infrared and system clock changes after upgrading to system9
Since upgrading to system 9 I have been unable to sync with my
palmIIx using the infrared port. I have a PBG3/333 bronze keyboard
with 192MB main memory. When I try to launch the infrared control
panel I get the message "The infrared control panel cannot run on
this machintosh because no infrared hardware was discovered." Is
this a hardware or software problem.
The other strange thing is that on wake up from sleep or start up my
system clock leaps ahead 1 hour and sometime 2 hours. I have it set
to PST (cuppertino) and set to update with a Time server when the
clocks are different. Toggling the automatic daylight savings time
setting makes no difference.
Thanks, David
[email protected]
Date: Fri, 12 Nov 1999 17:32:51 -0500 (EST)
Subject: VirtualPC-Windows95 or 98?
In Info-Mac Digest V16 #362, Marian C. Poczobutt asked:
>Does 98 run slower than 95, and are there any other costs or benefits?
I recently installed Virtual PC 3.0 on my G3 Powerbook but I have never
used an earlier verion so I can't make comparisons.
Another question was:
>Does VirtualPC recognize the serial ports on this adaptor, and if so does
>it need the USB
>support on the Windows side?
The reason I bought Virtual PC was that I wanted to run some trip planing
software with integrated GPS capability. I contacted Connectix tech support
to find out whether the PC software would be able to see the GPS receiver
and they said it would not. On the other hand, when I posed a question to
the same effect on an Motorhome forum, I got a reply from someone who said
he was using a GPS receiver which plugged in as a PCM-CIA card and the PC
software, running under Virtual PC on a Mac, could read it. I ended up
doing without GPS on a trial basis, figuring I would add it if I found I
really needed it. A recent 10,000 mile two month trip showed me that I
didn't really need it as much as I thought I would.
Ed Ver Hoef
Date: Fri, 12 Nov 1999 14:11:14 -0600
On 11/11/99 at 8:28 PM -0500, Marian C. Poczobutt wrote:
>I know that 98 offers USB support (with OS9), which brings me to my
>third question. I plan on getting an iBook soon and will use the
>Keyspan serial adaptor to connect devices such as a GPS unit to it.
>does it need the USB support on the Windows side? I'm guessing it
>doesn't, since the serial ports show up on the Mac side.
Here's what I hear from a friend at Connectix:
If you add a USB->serial adapter to your system and install the
included software which registers the "virtual serial port" with the
Communications Resource Manager (CRMSerialDevices.h), it will show up
in Virtual PC's preferences dialog and will be available for COM port
emulation.
So, yes, any Mac-compatible USB to serial adapter with the
appropriate drivers should do the trick.
pr
Pete Resnick
Eudora Engineering - QUALCOMM Incorporated
Date: Fri, 12 Nov 1999 15:05:35 -0500
Subject: why a 30 second delay sending e-mail?
--============_-1269685338==_ma============
Content-Type: text/plain; charset="us-ascii" ; format="flowed"
Gary,
I asked this question of Adam Engst a while back. He replied, "...
subscribe to the Eudora-Mac mailing list (linked on
) and ask there ..." There, without
having to ask, I found a thread that led to a clear answer. This is
a very useful Eudora site, giving me a real education in just the few
days I have monitored it. If you sign up, switch immediately to
e-mails in digest form (appears to be twice daily), or you will be
buried.
And the answer to this problem is:
In the menu - Special/Settings/Hosts - Deselect the "Use
mail-exchange records ..." options.
The result is the SMTP server responds almost immediately. My delay
was timed at 67 seconds before it found the SMTP host, and then about
11 seconds to send. Now the send is complete in about 15 seconds.
Steve Seiden
At 1:19 PM -0500 11/12/99, Info-Mac wrote:
>Date: Mon, 8 Nov 1999 16:08:28 -0500
>From: Gary Radice
>Whenever I send e-mail from Eudora on my bronze keyboard powerbook, there
>is a delay of exactly 30 seconds while my computer searches for my smtp
>server. Then the mail gets sent immediately. This happens both when I'm
>connected to the network in my office and at home over the modem/PPP.
>Receiving messages is not a problem. It finds the server immediately (plus
>or minus normal network delays) and sucks the messages down.
>But sending mail: exactly 30 seconds of wait, every time. I can switch to
>other apps in the meantime but I can't go back to reading mail or doing
>anything in Eudora until the 30 second search for the server is finished.
>Very annoying. Any thoughts?
>This is running OS 8.6 and Eudora Light 3.5.5.
>Gary P. Radice [email protected]
>Associate Professor of Biology 804 289 8107 (voice)
>University of Richmond 804 289 8233 (FAX)
>Richmond VA 23173 http://www.science.richmond.edu/~radice
Content-Type: text/enriched; charset="us-ascii"
Gary,
having to ask, I found a thread that led to a clear answer. This is a
buried.
right,right,left,leftIn the menu -
Special/Settings/Hosts - Deselect the "Use mail-exchange records ..."
options.
My delay was timed at 67 seconds before it found the SMTP host, and
then about 11 seconds to send. Now the send is complete in about 15
seconds.
Steve Seiden
>From: Gary Radice
there
smtp
I'm
(plus
to
doing
finished.
--============_-1269685338==_ma============--
Date: Sat, 13 Nov 1999 05:30:43 -0800
Gary Radice asked:
I don't have Eudora Light, but do use Eudora Pro. In my settings
(under Special menu) there is a category called "Threading" where you
can choose a delay before sending. You might look at the settings
relating to threading and see if that makes a difference.
Daly
Date: Sat, 13 Nov 1999 10:46:38 -0800
[[ This message was both posted and mailed: see
the "To," "Cc," and "Newsgroups" headers for details. ]]
In article , Gary Radice
In Eudora Light 3.1.3, under Hosts, there is a check box labelled 'Use
mail-exchange records (SMTP servers only)'. If that check box is
checked, Eudora will deliver the mail directly to the SMTP server that
the MX records indicate, with the delay you are experiencing.
Cheers,
Darrell
Darrell Greenwood mailto:[email protected]
Vancouver, BC http://www.nyx.net/~dgreenw/
--Info-Mac-Digest--
