Info-Mac Digest V16 #354
Subject: Info-Mac Digest V16 #354
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Thu, 21 Oct 99 Volume 16 : Issue 354
(A) Application Launch Ambiguity
[A] TCP/IP Question (multiple dial-ins)
alias/image of a CD as a mounted volume?
CD ROM drive problems
How to convert WriteNow4 files to Word97
Linux on a Mac
Macs Dialing in to NT Networks
MP3 encoder
TCP/IP Question
containing gigabytes of freely distributable Macintosh software.
the Subject line.
the Subject line.
form at before contacting us.
Info-Mac volunteers include Adam C. Engst, Demitri Muna, Hugh Lewis, Tom
Coradeschi, Shawn Bunn, Christopher Li, Patrik Montgomery, and Ed Chambers.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #354"
Date: Thu, 21 Oct 1999 19:54:58 +0900
Subject: (A) Application Launch Ambiguity
In Info-Mac Digest #353, Herb Kroemer asked:
> WDBN/MSWD: Different versions of MS Word (like 5.1 and 98)
> TEXT/CARO: Acrobat and Acrobat Reader
> Question: What controls which application is launched when I
> double-click a document with such multiple parents, if neither of the
> parents is already open?
Here is the answer:
--begin quote--
The following is from Apple's online publication
Information Alley, Volume II, Issue 3 (May 29, 1995):
The System 7.5 Finder Search Path
By Scott George
Here is how the Finder determines which version of the application to open
when you open a document and have multiple versions of the application
that created it on your hard drive.
* The Finder Search Path
The Finder searches for the correct application based on the "creator
type" of the document. The search path the Finder uses is as follows:
Step 1
The Finder first checks to see if an application with the same creator is
already running.
Step 2
The Finder searches the volume containing the document being opened.
Step 3
The Finder searches the startup volume.
Step 4
The Finder searches the rest of the mounted volumes.
In the event of multiple versions of the same application on one volume,
the Finder launches the application whose record in the desktop database
was updated last.
This is usually the last version installed.
--end quote--
[Note: For example, simply duplicating the application is enough to
"install" it as the last version.]
Mark
Mark Nagata
mailto:[email protected]
Date: Wed, 20 Oct 1999 23:53:48 -0400
Subject: [A] TCP/IP Question (multiple dial-ins)
>> I need to be able to switch between two ISPs for email and Internet service
>> (different domain names and DNS addresses)
Setting up multiple dial-ins requires defining additional
configurations for the TCP/IP and PPP (under OS 8.5 and 8.6, Remote
Access). In either Control Panel, under File, choose Configurations
and choose an existing configuration (you start out with only
Default), then click duplicate. Type in the name you want to give it
and then fill in the information given by your ISP. I have
configurations for my family ISP, my office local dial-in, alternate
long distance dial-ins when I'm on travel, and even a couple from
when I was out of the US. Now I've never been able to get it working
under OS 8.1, but under the later OSes, I use Location Manager to
define sets of Control Panels defining my settings for a "location",
and then I can switch the whole set from the Location Manager Control
Strip icon. That is amazingly powerful. If you switch settings
often, it alone is worth the 8.5-8.6-? upgrade.
Ken Laskey
Date: Wed, 20 Oct 1999 22:13:34 -0400
Subject: alias/image of a CD as a mounted volume?
Would someone be kind enough to tell me how I might go about making
an alias (or some sort of image) of a CD that will pretend to be a
mounted volume so that those (generally older, in my experience)
programs that look for a mounted CD volume to work with will operate
properly? Ordinary aliases don't seem to be recognized as true
volumes. Of course, I have plenty of room on my hard drive (25GB) to
accommodate the whole of the CDs (one is the American Heritage
Talking Dictionary) in question.
Gratefully,
Bill McCarthy
Date: Thu, 21 Oct 1999 12:56:17 -0400
Subject: Application Launch Ambiguity
>Certain Type/Creator combinations are shared by related but different
>APPLication. For example:
>In both of the above examples, I need one of the two parents 95% of the
>time, but when I simply double-click on a document, the "5%" parent
>launches. This is a big nuisance, which forces me to employ a different
>launching procedure 95% of the time.
>I know of course that there are various other ways to get the desired
>application to launch; but none of them is as simple as just
>double-clicking the document, and I would like to control the
>double-click procedure itself.
Open the 5% parent in an application that lets you change FILE CREATOR
code. Change the FILE CREATOR to something else (e.g.--MW98 instead of
MSWD or ACRB instead of CARO). You can still launch these applications and
then use File:Open to open whatever documents you wish to edit. However,
if you double-click a file, the other parent (the "95% parent") will be the
one that launches. Files created by your modified application will
continue to have the original correct FILE CREATOR code, so if you
double-click a Word98 document created in Word98 after changing the FILE
CREATOR code of W98 to something else, your older copy of Word will launch
and try (and probably fail) to open and display the file; but if you email
the file to your friend, your friend's unchanged, unmodified copy of Word98
will be the one to launch when the file is double-clicked.
Allan Hunter
Date: Thu, 21 Oct 1999 17:13:36 +0100
Subject: CD ROM drive problems
Hello>
I have a CD rom drive (internal) that refuses to read many CDs. My
machine is a PowerComputing and CD drive is driven by FWB's CD-ROM
Toolkit 3.0.2 (the latest). I have internal and external HDs and both
have system folders on them and both read or refuse to read the same
CDs. Has anyone come across the same problem? Are CD drives known to
break down in this erratic manner?
Any advice would be appreciated.
> Ezra
Date: Thu, 21 Oct 1999 09:29:41 -0400
Subject: How to convert WriteNow4 files to Word97
On 10/20/99 2:25 PM -0500, Tapas Kar wrote:
>I have more than 500 documents (files) in WriteNow version 4.0 and like to
>convert all of them to MS-Word97 version by a single click. How to do this
>either in MAC
Dataviz MacLink Plus http://www.dataviz.com/ will create a "drag &
drop" converter that you can drop the whole mess on (probably at
bedtime for 500 documents as it's likely to take until morning to
convert them all :-)
-Murph
Date: Wed, 20 Oct 1999 18:55:38 -0700
Subject: Linux on a Mac
I was wondering if anyone has had any success with Linux on a
Macintosh. I am working with someone who has been trying to install
Linux on a cluster of Macs, with limited success. She was able to
get Linux up and running on a single computer, but we found the
performance was lacking.
A PC Guru informed us that Linux on the Mac still has to run through
the "Mac OS GUI", and that was why the performance lacked. Is this
true?
If anyone knows of any available information on setting up Linux on a
single Mac or a clusters that would also be appreciated.
Thanks
Stephen
Date: Wed, 20 Oct 1999 22:36:40 -0500
Subject: Macs Dialing in to NT Networks
Greetings:
I am attempting to dial into our company network from home using my Mac.
Problem is that the NT network uses DHCP over dialup (PPP) and requires
registration with a WINS server that Open Transport 1.3 (I'm running MacOS
8.1.) or even OT 2.0 doesn't support. After snooping around a bit, it
appears that Thursby Systems DAVE has a NetBIOS driver that might solve the
problem. Is this a correct assessment of the situation (Network protocols
and NT aren't my strong suites yet.) and does anyone have any other
suggestions for solving this problem.
Thanks in advance,
Mike Sisson
Date: Thu, 21 Oct 1999 11:49:32 +1000
Subject: MP3 encoder
>Does anyone know of a serviceable freeware/inexpensive shareware MP3
>encoder?
>TIA
>Simon H
Check out N2MP3, haven't seen an easier, more intuitive one around.
The quality sounds fine to me but I'm not an audiophile.
Best feature is it interacts with the CDDB (CD Database www.cddb.com)
and fixes Audio CDs inserted into your computer so the disk has the
right name and all the tracks are named. Neat Huh?
BTW: Drag and drop conversion ... drag a file from a CD to a hard
drive and it will automatically encode it (or save as an AIFF if you
want!)
Cheers!
Richard Measham
iSite Internet Presence Development
Level 1, 80A Mercer Street
Geelong 3220
http://isite.net.au
Date: Thu, 21 Oct 1999 12:46:33 -0400
Subject: TCP/IP Question
>Running OS 8.1 on a G3, I need to be able to switch between two ISPs for
>email and Internet service (different domain names and DNS addresses).
>It's probably obvious, but I can't figure out how to get two TCP/IP
>options. I see "Select hosts file" in TCP/IP Setup but don't know how it
>works. Advice urgently requested and most gratefully received.
>Ted Logan
>Logan Writing, Inc.
>[email protected]
a) Open TCP Control Panel
b) Go Command-K to open configurations dialog box.
c) Rename existing configuration (probably called "Default") to ISP#1 name
d) Duplicate existing configuration
e) Renamed duplicated configuration to ISP#2 name
f) Edit parameters of second configuration so that it works with ISP#2.
>From now on, to switch ISPs, open TCP Control Panel, go Command-K, switch
configurations, click "Make Active", close window.
Oh...if both ISPs are accessed via modem (PPP), perform all of the above
steps except do so from the PPP control panel instead.
Allan Hunter
--Info-Mac-Digest--
