Subject: Info-Mac Digest V16 #350
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Wed, 13 Oct 99 Volume 16 : Issue 350
4 int HDs into 1 ext scsi unit, part 2
[Q] Modem dialing (Powerbook v.34) setup in Touchbase Pro
Action Utilities GoMac 2.0.3 buggy
Apple CD Audio Player
Do we need a new digest viewer?
Easy View - Do we need a new digest viewer?
How can you change default browser? Solved!
Java with IE
Record of in and out to internet
scientific calculator
The three ADB device rule
transparent backgrounds for desktop icons
turning int. HD into ext. HD and Linux
Weird problem with letter 'd'
containing gigabytes of freely distributable Macintosh software.
the Subject line.
the Subject line.
form at before contacting us.
Info-Mac volunteers include Adam C. Engst, Demitri Muna, Hugh Lewis, Tom
Coradeschi, Shawn Bunn, Christopher Li, Patrik Montgomery, and Ed Chambers.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #350"
Date: Wed, 13 Oct 1999 15:32:36 -0400
Subject: 4 int HDs into 1 ext scsi unit, part 2
Hello,
Oops! I forgot one last question-
Assuming that I can join all 4 drives into 1 unit, is there a hardware
(or software) solution to make them all look like 1 2GB drive? Or must
it always appear to be 4 500MB drives?
TIA,
Carolyn
[email protected]
Date: Wed, 13 Oct 1999 00:57:06 -0400
Subject: [Q] Modem dialing (Powerbook v.34) setup in Touchbase Pro
quoting Info-Mac and possibly previous message abstract:
>Date: Fri, 08 Oct 1999 21:12:38 -0400
>From: [email protected] (TCS)
>Can anyone help me with what to fill in for the following categories?
>Modem setup string
>Modem dial string prefix
>Modem hangup string
>TIA,
>lc
You could try They have most init strings
for most modems.
I know that apple has an unsupported Modem Script Maker somewhere in its
support area under Mac OS Communications Unsupported I believe. I made
one for my GV teleport a long time ago when I wasn't happy with the
throughput on my 33.6 modem. It was several years ago but is definitely
in one of the unsupported areas. Perhaps a search in the Apple support
area for ModemScript or Script Generator etc may locate it for you. HTH
>>>-----------Reach me by ICQ# 7162477------------------=80=80=80
Date: Wed, 13 Oct 1999 00:30:40 -0400
Subject: Action Utilities GoMac 2.0.3 buggy
Dear Digest readers,
Action Utilities GoMac 2.0.3 has a very serious problem. While being
a nice alternative to the windows 95/98/NT toolbar on the Mac, if the
toolbar is active you can't quit from many open applications. This
is regardless of if auto-hide is enabled or not. If I try to quit
from many applications, the cursor starts to twirl a clock, and then
"The Finder has unexpectedly quit" error appears on my screen. I
even tried renaming the GoMac extension to ZGoMac to no avail. So
load order of INITs doesn't matter in this case. I've tried e-mailing
action utilities but all I get is an automated reply. Turn off the
toolbar, or disable the extension, the error doesn't happen in the
same programs.
Please somebody help.
Thank you.
Sincerely,
[email protected]
Check out over 700 internet sites updated monthly at:
http://www.index-site.com
Date: Tue, 12 Oct 1999 17:58:18 -0400
Subject: Apple CD Audio Player
>When I put an audio CD into the drive on my G3 with 8.1, the CD's icon
>appears, and I usually get a few seconds of music. Most often, however, I
>have to double click the CD, click the icon for the first movement, and then
>Apple CD Audio Player starts, and I get its screen. If I wait a few seconds
>more, the music starts, without my intervention, unless I choose, by clicking
>a track, to listen to something other than the track that I had double
>clicked initially. If I click the box to get rid of the screen, the music
>continues. But the audio program is not on the pulldown menu at the right
>side of the screen.
>Can someone explain all of this? Is Apple CD Audio Player running or not,
>and why no mention in the list of running programs?
Apple CD Audio Player is a control application, but there are other means
of playing audio tracks. One of them is the auto-play option listed in
QuickTime Settings, which causes an audio CD to start playing whenever you
insert it.
If you want to use only the CD Audio Player (a good idea; viruses spread by
things that autostart themselves without user intervention), turn all
AutoPlay options off in QuickTime Settings Control Panel; launch the Audio
Player first and click the "play" button to start playing audio tracks.
Allan Hunter
Date: Wed, 13 Oct 1999 00:36:59 -0400
Subject: Do we need a new digest viewer?
>I, too, read Info-Mac and TidBITS in Easy View, and I'm also looking
>for a replacement for that ancient program.
I'm using a program called Digest Viewer (v3.0b2)...
http://www.macrules.com/users/mjh/
...for viewing Info-Mac digests, and it works very well so far. It doesn't
know about SEText, yet.
-Eric
Eric Frampton, keyboards
Atlanta, GA / 404-932-4017
Date: Wed, 13 Oct 1999 08:44:19 -0400
Subject: Easy View - Do we need a new digest viewer?
>M. Akif Eyler halted development of Easy View at version 2.61 of March
>1995. I seem to remember that Adam Engst has mentioned the possibility of a
>rewrite on the TidBITS list and that Mr. Eyler would be willing to supply
>the source code. Apparently no programmer has risen to the challenge.
>Perhaps Adam Engst - a moderator of this list - will correct or elucidate?
Certainly. In October of 1998, Akif sent me the source code for Easy
View, and I posted it to Info-Mac. Anyone who wants to update it - go
right ahead (I don't remember the license terms offhand, but they
were along the lines of public domain).
cheers... -Adam
Adam C. Engst, Info-Mac Senior Moderator --
Date: Tue, 12 Oct 1999 18:06:01 -0600
Subject: How can you change default browser? Solved!
Thanks to those who responded to my post:
>How can you change the default browser from Netscape to MSIE
>after both are installed, you know, the one which launches
>when you double-click an URL? I know that when you first
>install either browser, you can choose to make it the default,
>but is it possible to change it later?
>I have MacOS 8.1, so I can't switch it from the Control Panels.
>Thanks......Larry
The solution is to change the HTTP HELPER in Internet Config and then
to choose "Read from Internet Config" in Eudora's Miscellaneous
Settings.
Date: Tue, 12 Oct 1999 16:24:08 -0400
Subject: Java with IE
I need to access a site using Microsoft's JVM (rather than Apple's)
with Internet Explorer, but even though I set the preferences to
Microsofts Java Virtual Machine, whenever I access the site it
switches to the Apple MRJ and then I get errors. I'm using IE 4.5.
Alan H. Stein [email protected] http://www.alanstein.com
Date: Wed, 13 Oct 1999 09:02:17 -0400
Subject: Record of in and out to internet
I understand that the Windoze world has programs such as DIRT, which place
hidden execs that record keystrokes, etc. and send them back out as an
encrypted file under cover of other internet traffic.
Given the hackers about us, and the abyssmal lack of privacy today, is
there a program that could record the filenames, size, etc. and location
placed, of all files transmitted into my Mac from an outside source and all
files transmitted out to the net exclusive of those dilberately sent by the
computer operator?
Is there one that would act similar to a virus scanner and allow you to
view or at least yes or no an outgoing request? Or one that would trap the
info leading back to the originator?
It would be especially useful to have a folder into which is placed copies
of everything sent so that an anlysis could be made.
You can email answers to [email protected]
TIA
Date: Wed, 13 Oct 1999 10:07:35 +0100
Subject: scientific calculator
Hello>
I'd like to download a scientific calculator - something that has
very similar functions to any regular one I might buy as hardware.
Does anyone know of one I can download, preferably freeware or
shareware? It would be nice if its 'facia' was similar to a hardware
one.
> Ezra Nathan
Date: Tue, 12 Oct 1999 17:49:55 -0400
Subject: The three ADB device rule
>So remember, you can only add ONE device to the ADB port of the
>Wallstreet. Add any more, even if built into the single device you
>think you are adding, and you are risking disaster.
Hmm?? I use an extended keyboard and mouse with my Wallstreet all the time
except on the train. At the moment, prompted by curiosity caused by the
above post, I am typing on keyboard #1 of 3 external daisychained ADB
keyboards, the third of which has an external mouse hanging off the end of
it. Keyboard #2 working fine...Keyboard#3 doing okay as well...Built-in
PowerBook keyboard works...mouse is OK...trackpad works...
Allan Hunter
Date: Wed, 13 Oct 1999 12:25:28 -0400
Subject: transparent backgrounds for desktop icons
Hello,
Does anyone know of a program or a way to make the background of the
text of desktop icons transparent? I like to use photographs as my
desktop, and I just hate the look of the greyed-out text "boxes". On my
PC at work I have a neat freeware app that does just this, but I have
not been able to find a similar program (or setting) that will
accomplish this. I am using a beige G3, and OS 8.6. Kaleidoscope really
doesn't seem to be the answer either. I quite comfortable with ResEdit,
so if that is my only solution, then that's OK as well.
TIA,
Carolyn
[email protected]
Date: Wed, 13 Oct 1999 15:26:45 -0400
Subject: turning int. HD into ext. HD and Linux
Hello,
I have 4 500 MB internal HD's that I would like to combine into 1
external HD scsi device. They are all Mac HFS drives. I don't know
anything about building such a thing, so I would appreciate any advice
at all. and I have a number of questions. At the very least, I would use
it as a back-up for my main HD. At the very most, please see below for
my Linux plan. But first of all the basics-
1. Can I do this? Is it OK to run 4 hd's off of 1 power supply?
2. Can I daisy chain 4 hds together like this? ( There must be hd to hd
cables?)
3. What do I need, and need to know to do this? (I've swapped HDs and
installed RAM, so I know how to be careful, and how to plug things in.)
I also would appreciate knowing if there are brands to either look for
or stay away from. I know that I need the power suppy (but what wattage
or other details?), cables, mounting brackets and a box. I feel that I
am quite capable of doing this if it is really a reasonable thing to do.
4. Is this a really dumb idea? ie-dumb, it simply won't work; or dumb,
that I should have a professional do this?
5. I assume that I can reformat them as HFS+ drives (if they are to be
used for back-up purposes)? I mean, is there a difference in the actual
HD media for HFS vs HFS+?
However, my ideal plan is to combine all 4 units into 1 box, and then
install Linux on it. Right now, I only wish to use this "Linux box" as a
self-training machine (I know some unix, and have signed up for the
unix/linux course at ZDU). But there would be no networking, except to
my Mac which is a beige, 300- G3. It wouldn't be used as a server or
anything. I'm hoping that I can do this so that I do not have to
reformat my main HD, but if I must, or if this seems to be a really bad
idea, then I can use the external drives as a back-up, re-format the
main HD, and then continue. I've joined the linuxppc-users-digest list,
so I'm lurking and learning about the linux side of things there as
well.
I hope I've explained everything well enough, and I appreciate any and
all feed back- especially if these sound like dumb ideas! I really trust
your collective wisdom...I will summarize my findings for all of you.
TIA!
Carolyn
[email protected]
Date: Wed, 13 Oct 1999 15:24:29 +0100
Subject: Weird problem with letter 'd'
In Eudora (4.2) every time I type the letter 'd' it opens the control panel
folder!!!!!!!!!
To type 'd' I have to open and use PopChar pro. I tried closing Euxora and
restarting it but no difference. So far I don't know whether it affects any
other applications but it also happens when
I'm in the Finxer and type the letter 'd'. It does not happen if I type a
uppercase 'D'!
PowerMac5500; OS8.6.
Any suggestions that could point me in a direction?
Awrabest
Lobo.
ta reply, rub oot -Lobo- from... [email protected]
--Info-Mac-Digest--
