WhiteKnight script for CI$ v.06/01/92 (5th version)
Download: http://archive.info-mac.org/comm/term/w ... cripts.hqx
What follows is extracted from the ReadMe file.
> WKAUTO.SEA is a set of White Knight scripts for automating access to the
> CompuServe Information Service.
> The set is shareware and a fee of $10 is payable to:
> Alex Narvey
> Thunder Enlightening Press
> P.O. Box 332, 905 Corydon Ave.
> Winnipeg, MB, Canada R3M 3V3
> Telephone & FAX (204) 488-8306
> WKAUTO.SEA - The complete set
> WKCOST.SIT - PROCs for creating and maintaining cost/session logs
> WKDOC.SIT - The manual for the WKAUTO PROC set
> WKDOWN.SIT - PROCs for automatic downloading
> WKFAX.SIT - PROCs for automating sending Faxes
> WKMAIL.SIT - PROCs for automatic E-mail sending and retrieval
> WKMENU.SIT - PROCs to generate custom menus to run the set
> WKSUMM.SIT - PROCs to automatically download forum summaries
> WKUP.SIT - PROCs to automate uploading files
> WKZMAC.SIT - PROCs to auto-download ZiffNet/MAC files and MacWEEK news.
> The individual files in the series are provided for convenience and for those
> who have already previously downloaded the set and only wish to upgrade part
> of it - although I don't guarantee that partial upgrades will work. I
> reccommend downloading WKAUTO.SEA which includes the manual and all
> procedures - including some that don't make it into the individual series.
> You may download and use any part of the set without the others. However the
> custom menus in WKMENU.SIT make things easier. And of course, even if you
> don't have or use all the PROCs it would help to have the manual (WKDOC.SIT).
> All PROCs are supplied in MacWrite format so that you can modify them if need
> be and therefore need to be compiled into Procedures by your own copy of
> White Knight.
> There are special criteria that have to be incorporated into your LogOn
> procedure if you want the Cost and Session Logs to work properly.
> Furthermore, the LogOn PROC relies on the GetMail subroutine in WKMAIL.SIT
> for the E-Mail Log to function properly. In short, youUll particularly need
> the manual if you are working with the Cost, Session and E-mail Logs supplied
> with WKCOST.SIT.
> Warning
> The PROCs have been designed to run on and have been tested under System 6.0x
> and 7.0x with 1200 and 2400 baud modems. However, NO EXPRESS OR IMPLIED
> GUARANTEE IS OFFERED THAT THESE SCRIPTS/PROCs RUN PROPERLY ON ANY GIVEN
> SYSTEM CONFIGURATION.
> If you experience problems I am available to offer script editing advice.
> Just send me an E-mail to the 71041,132. Again, I offer no warrantee that my
> advice will fix a problem.
This submission only includes the complete set. I am not the author and just
found these in the CI$ Communication Forum a few days ago. I even have no
time to fully test drive it yet. If you have any question, please contact the
author.
Alex Narvey
Liu
P.S. If there is interest from the net fo get individual file, I can try to
get them. However, there is no guarantee that I can finish it immediately.
