White Knight IBM3270 macros
Download: http://archive.info-mac.org/comm/term/w ... 0-keys.hqx
This keyboard macro file defines 3270/3278 terminal keys for use while
interacting with IBM mainframes with White Knight. Simply choose
customize-macro keys-load (command M-L) and you're all set. You may use the
macro edit dialog to redefine keys as required. The file is setup for
extended keyboards so you will need to redefine the function keys if they
don't appear on your keyboard. This file is freeware, uploaded by
"M.Crouch2" on GEnie to the Freesoft forum. I presume he/she is the author.
Jeff Needleman
