Info-Mac Digest V16 #334
Subject: Info-Mac Digest V16 #334
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Thu, 02 Sep 99 Volume 16 : Issue 334
(A) AudioVision14 Monitor, 11" viewable
(A) World Book CD
[A] midi files on the web
[A] Sherlock search of Info-Mac files?
[Q] info about movie viewer
[Q] MoviePhile? Chris Crabtree?
[Q] Unable to sort Bookmarks in NS 4.0.8?
Battery problem on PB1400cs
Blocking animated graphics in web browsers
Boot problem
Eudora addresses
eudora-to-browser problem
MP3 tag editing.
Replacing hard disk on Performa 5200
World Book CD
containing gigabytes of freely distributable Macintosh software.
Email Addresses and Instructions:
the Subject line.
the Subject line.
form at before contacting us.
FTP and Web Addresses and Instructions:
* To submit files larger than 800K, email a description to
* A full list of Info-Mac mirror sites is available at the URL below:
* Search the archive at .
Info-Mac volunteers include Gordon Watts, Adam C. Engst, Demitri Muna,
Michael Bean, Liam Breck, Hugh Lewis, Tom Coradeschi, and Shawn Bunn.
the main Info-Mac machine.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V16 #334"
Date: 28 Aug 99 20:20:50 -0400
Subject: (A) AudioVision14 Monitor, 11" viewable
[email protected] writes:
>I have a Mac 71/66AV with a AudioViosion14 with the High density cable
>that
>is hard wired, that has now a 11" viewable area on the screen instead of
>the
>13" it's supposed to have. I have done everything to try to correct it:
new
>sys, updated monitor software, reset monitor and tried all kinds of 3rd
>party
>stuff.
>It also will not allow me to turn off that it thinks a TV set is connected
to
>it and so my cursor disappears to a ghost sceen when moved to the border
>of
>the monitor so it's seeing 2 desktops.
>I am going blind with such a small view area and have called Apple, went
to
>tech info etc. with no luck. They are not sure either...... Really need
>some help.
Mark:
How about resetting the PRAM? Either use TechTool or at startup hold down
cmd+opt+P+R untill the Mac restarts 5 or 6 times. It may help.
- Scott
Remove the "spamless" to return eMail to me.
Scott Beach Toronto, Canada
Date: 28 Aug 99 20:10:19 -0400
Subject: (A) World Book CD
Buzz Bennetts writes:
>I am a (expert) volunteer at a local library that just bought its first
>iMac. They wanted to install everything from both World Book
>Encyclopedia CDs that came with the iMac onto the hard drive. They did
>not want the CDs to disappear in use by the 6- thru 12-aged users.
>I first installed the basic application; then the data from each of the
>two CDs onto the HD, and labeled them exactly the same as each CD is
>labeled. I put them into the World Book folder. I have done similar
>things with CDs many times, and they always have worked fine, but this
>application keeps calling for the appropriate CD.
>I emailed the World Book folks, who answered there is no way to make it
>work that way. I find it hard to believe. Does anyone have a suggestion?
Buzz:
Make a disk image of the CD and mount it on the desktop. That may fool the
application as it will see it as the actual disk.
You can use Apple's Disk Copy utility to do this.
- Scott
Date: 28 Aug 99 18:55:38 -0400
Subject: [A] midi files on the web
"D & E Rogers" ask:
>Every time I encounter a midi file on the web, my computer freezes at
about
>the time I think it ought to start playing the sound. Where do I need to
>look to change my settings in order to prevent this? (I have tried
>un-checking "Play Sounds" in Explorer's preferences to get around the
>problem, but no luck - it freezes anyway. Of course, I would prefer to be
>able to hear the sounds.)
D &/or E:
I think that web browsers can only play wave and maybe .au files. Turning
on or off the sound playing prefs probably won't effect how the browser
treats midi files. I expect that what you need is a plug-in to read midi.
The most recent Quicktime installs with a plug-in that should do that. Just
in case it doesn't then check the IE or Netscape home pages for plug-in
info. They'll have the right one for you.
- Scott
Date: 28 Aug 99 19:00:38 -0400
Subject: [A] Sherlock search of Info-Mac files?
"David L. Ellis" asks:
>I would like to know if there is a Sherlock plugin for the
>HyperArchive or other collection of Info-Mac files?
David:
Mine has the update URL:
http://www.vetvir.unizh.ch/programs/Inf ... ve.src.hqx
Go fetch.
- Scott
Date: Mon, 30 Aug 1999 14:52:24 +0100
Subject: [Q] info about movie viewer
Hello:
Does anyone know a Mac movie viewer for the Advanced Streaming Format
from Microsoft (extension .asf)?
Thank you
MJMatos, Coimbra, Portugal
Date: Fri, 27 Aug 1999 15:35:21 -0700
Subject: [Q] MoviePhile? Chris Crabtree?
Anyone know how to contact Chris Crabtree (or new owner) of MoviePhile? I
have been using the trial version, and wish to purchase registration. His
web site http://tacitblue.home.mingspring.com/moviephile and mail
[email protected] no longer exist.
Any help appreciated. --Jim Sanders--
Date: Tue, 31 Aug 1999 22:02:27 +0100
Subject: [Q] Unable to sort Bookmarks in NS 4.0.8?
If I am to have any hop of keeping track of my very large collection of
Netscape bookmarks I need to sort them alphabetically within folders
created in the Bookmarks window, which folders are themselves arranged
alphabetically. Folders created within the Bookmarks window appear to be
automatically sorted alphabetically but I can find no way (other than
manual positioning) to sort the folder contents alphabetically.
According tothe Nnetscape 4.0.8 On-Line Help file:
'The Bookmarks window contains a menu bar similar to that of
the Navigator window.'
and:
'The View Menu
By Name arranges bookmark folders and items within
folders alphabetically by name.
By Location arranges bookmark folders and items
within folders alphabetically by URL (disregarding URL
protocols such as HTTP and FTP).
By Created On arranges bookmark folders and
items within folders chronologically by the date the
bookmark was created.
By Last Visited arranges bookmark folders and
bookmark was last displayed.
Sort Ascending arranges alphabetical views from A
to Z, chronological views from newer to older, and
numerical views from 1 to 9.
Sort Descending arranges alphabetical views from
Z to A, chronological views from older to newer, and
numerical views from 9 to 1. '
Despite this, in my version of Netscape, the Bookmarks window does not
- as seems to be implied here -have its own set of menus and none of these
menu commands appears in theView menu of the Netscape window when the
Bookmarks window is open and tothe front. I am using NS 4.0.8 on G3
Minitower using OS8.5 but I have hadsimilar results on a PPC running OS 7.6.
I am utterly frustrated and baffled. Can anyone help?
TIA -
Fergus Lalor
Date: Tue, 31 Aug 1999 14:33:16 -0400
Subject: Battery problem on PB1400cs
Try resetting the power manager, it being a bit scrambled can cause such
anomolies. Reseat the battery, and if possible, test it with a known-good
battery, to make sure the fault isn't there.
>I have a Powerbook 1400cs running 8.5.1. When running on battery power, I
>get the "you are now running on reserve power...etc" alert while I still
>have loads of battery charge left (all seven bars in the control strip
>monitor). The irritating thing is that the alert signals a dimming of the
>screen which I can't reverse; I then have to work with a dimmed screen for
>the rest of my time on battery power.
>NB this problem has persisted through (unrelated) processor and logic board
>replacements.
>Anyone have any ideas on how to rectify the problem?
>Simon Hardeman
>Home page: http://website.lineone.net/~simonhardeman
Date: Fri, 27 Aug 1999 15:11:25 +0200
Subject: Blocking animated graphics in web browsers
Is there a way to block animated graphics in Netscape and Explorer on
the Macintosh. I would prefer something which does not remove them,
just stops them from animating, or even better, lets me control whether
they should animate or be still.
I would also like to stop advertisement pop-up-windows, but is it
possible for software to separate desirable and unwanted pop-up-windows?
I have heard rumours that something called "client-side proxies",
for example Muffin, can do such things. Do anyone have any experience
with such tools on the Macintosh?
Date: 28 Aug 99 19:07:50 -0400
Subject: Boot problem
Patty and Art Werschulz ask:
>The following has been happening recently, when I boot my Mac:
>After the usual startup sound, there is a pause of a few seconds (during
>which the Mac makes what seems to be the usual disk noises). But then I
>hear (for lack of a better description) the sound of breaking glass
>(from the speaker). Nothing else happens.
>I'm now having to do the boot cycle three or more times (as a rule) to
>get the Mac to successfully boot.
>What does all this mean, and what is the fix?
Patty and Art:
Back on the Centris 650 or thereabouts the sound was screeching tires and a
car crash. Isn't it wonderful?
You might try pulling out one of the DIMMs (or whatever flavour of RAM it
takes) at a time if you've got more than one to see if you've got a bad
one.
- Scott
Date: Sat, 28 Aug 1999 20:11:39 -0700
Subject: Eudora addresses
At 3:30 PM -0400 8/16/99, Norman Friedman wittily wrote:
>When updating my system, I found that my address book in Eudora was wiped
>out. When I then re-entered all the addresses, lo and behold all the old
>list was listed, along with the new addresses, not in the address book,
>but
>under the Message list. Whenever I try to send a New Message or Forward, I
>have to try to pick which is the active address. I cannot seem to find a
>way to erase the names from the Message listing. Any help. Thanks in
>advance.
>[email protected]
This should work I believe:
Quit Eudora, open your Eudora Settings file in ResEdit and delete the
'MENU' resource.
Curiosity killed the cat,
but satisfaction brought it back.
ICQ#5066430
Blessings, Denny
Date: Tue, 31 Aug 1999 14:32:26 -0400
Subject: eudora-to-browser problem
That translates as an 'end of file' error. It could mean;
0000,7777,00001-That Eudora itself is to blame,
as "Sorry; couldn't start that application." is something I see when
Eudora occasionally loses its link to SpellSwell..
But from what I can see, it does rely on the OS to supply an app to
handle the URL..
0000,0000,FFFF2-That the preferences for the
internet control panel have been corrupted. (This is the system
component that keeps the settings of which browser you've set as the
default.)
*Some suggestions;
Make sure "Default Web Browser" under the Web tab has an accurate
selection.
If that doesn't help, Trash the preferences ("Internet Preferences")
Hilite a URL in another app like Stickies, drag it to the desktop, (It
will create a MacOS URL clipping file)- double click that. If that
fails to launch your preferred browser, it's more likely the Internet
settings than Eudora's fault.
>Hi.
>I am having a problem clicking on URL's that appear in e-mail
messages. I
>recently set up a new iMac and I had never had the problem before.
When I
>receive an e-mail with a URL, the URL appears highlighted in blue and
>underlined as it should be, but when I click on it, I get the
following
>message:
> "Sorry; couldn't start that application. -39, {url:283}"
>Theoretically, it should just open the default browser and go to the
>particular site automatically. Does anyone have any input? Thanks
in
>advance!
>RJS
Date: Sat, 28 Aug 1999 20:17:07 -0700
At 11:43 AM -0400 8/19/99, Ricardo J. Seijo wittily wrote:
>Hi.
>I am having a problem clicking on URL's that appear in e-mail messages. I
>recently set up a new iMac and I had never had the problem before. When I
>underlined as it should be, but when I click on it, I get the following
>message:
> -39, {url:283}"
>particular site automatically. Does anyone have any input? Thanks in
>advance!
>RJS
Try resetting the browser that Eudora will try to open, hold the option
key and double click on the URL and then choose your browser.
Eudora doesn't use InternetConfig. ;-{
ICQ#5066430
Blessings, Denny
Date: 29 Aug 99 19:59:59 -0400
Subject: MP3 tag editing.
Dear list readers:
I occaisionally run into a situation where my encoded .mp3 files are not
tagged correctly. Maybe I've typo'd or got the date wrong... whatever. Is
there any way to open an .mp3 file and edit the tags? If there isn't such a
utility then is it something I could write in RealBasic or other? (I've
been looking for an excuse to learn it.)
Thanks for reading.
- Scott
Date: Thu, 2 Sep 1999 00:40:39 +0900
Subject: Replacing hard disk on Performa 5200
Can anyone please provide instructions for replacing the
IDE drive of a Performa 5200.
1) Does it have a front that pops off like a 630? (i.e. slots
below front panel, insert two long screwdrivers and lift).
2) Is the hard disk mounted on plastic rails like in the 630?
Date: Tue, 31 Aug 1999 14:33:05 -0400
Subject: World Book CD
Some titles' applications are made so that they expect to see those
directories on the desktop, whether that is from the appropriate CD being
mounted, or a folder on the desktop by the same name that you've created.
Still others access partitions on the CD that you & I don't see, where data
is stored. More cross-platform titles are like this. I suspect it's the
former, so give that a whirl?
Now that I've tried it myself, I think they're right. My 1st suggestion
failed......
>Thanks!
>Buzz Bennetts
--Info-Mac-Digest--
