iOrganize 3.0 - Advanced NotePad, Address book, File Manager
Download: http://archive.info-mac.org/app/i-organize-30.hqx
package
The final version of iOrganize 3.0 has been released.
iOrganize is a multipurpose organization package which features an advanced
and flexible notepad able to easily store notes in multiple categories with
powerful search abilities, as well as an address book and a file manager
able to store aliases of commonly used files and applications.
This new version introduces new text editing abilities, breaking the 32 kb
per note limit, supporting multiple undos/redos, allowing mixed
fonts/styles... The "AliasPad" module has been redesigned to allow Finder
icons to be displayed, and iOrganize 3.0 is also now fully "TSM Aware" to
better support Japanese systems.
iOrganize is a $15 shareware.
web site :
http://www.brunoblondeau.com/iorganize
download link:
http://www.brunoblondeau.com/iorganize/iorganize30.sit
author email:
Version 3.0 Changes :
- NotePad&ContactPad : NotePad notes and the ContactPad note field can now
store more than 32 kb of text, only limited by memory. This version also
adds a lot of keyboard shortcuts for easy navigation and edition such as
triple clicks, selection using shift+arrow, option+arrow,...
- NotePad : Added a Font menu, which let you edit precisely the fonts in
your notes, as well as a size menu for font size selection, and a style menu
(usual styles, justification and text color selection)
- NotePad : Fixed a bug in the search window when text from a previous
search was still displayed
- NotePad : faster scrolling of the text
- NotePad : Multiple Undo and Redo support (also in the ContactPad note
field)
- NotePad : The user is now always asked to confirm Category deletions
- NotePad : iOrganize is able to use temporary memory for very long texts
- NotePad : Fix : The previous note was still visible when creating a new
category
- AliasPad : 3 kinds of display are now available for the alias list : text,
small icons, big icons
- AliasPad : Finder-like appearance both for the right column
- AliasPad : Up&Down arrows let you move into the list
- AliasPad : Corrected some cosmetic bugs when switching from another
application
- AliasPad : Added an AliasPad tab in the preference dialog, with 3 options
: Open AliasPad when iOrganize is launched, Remember the position of the
AliasPad, Quit iOrganize when clicking on the close box
- Added a "Module" menu
- Reorganized the menus, so as to display only the ones relevant to the
currently used module
- Added Cmd-Shift-Z as keyboard equivalent to Redo
- Improved the About and Register dialog to add Internet links
- Minor Bug fixes and memory optimizations
- iOrganize is now TSM Aware with Inline Input support (useful for Japanese
systems, etc.)
