Download: http://archive.info-mac.org/comm/term/k ... plates.hqx
Four templates to use with MacKermit the free communication program are
included. On a MacPlus you can use them and the COMMAND key will replace the
CONTROL KEY. Even if now I have a keyboard with arrows and a control key, I
still use these templates.
These could be archived like you want.
louis [email protected]
Here are the UNIX server programs needed to use the MacLayers 1.30
multiple window terminal emulator. The file is in shar format,
compressed and uuencoded.
This file should replace unix/maclayers-unix-side.shar
begin 644 layers_1.30_unix_files.shar.Z
