Info-Mac Digest V15 #133
Subject: Info-Mac Digest V15 #133
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Wed, 02 Jul 97 Volume 15 : Issue 133
Applescript and PPP...
Background driver for Imagewriter
Desktop rebuild problem
DeskWriter 320 AppleTalk driver
Find by time?
Hundreds of fonts online: how best to organize?
Power Mac DebugServices
TransCryptor (Cyr) 2.0
Type 11 errors (solved)
VGA to Mac Problem
Gordon Watts, Adam C. Engst, Demitri Muna, Mike O'Bryan,
Michael Bean, Matt Bauer, Liam Breck
Files for inclusion:
and upload it to:
all of this info and more!
The Info-Mac digest is sponsored in part by StarNine Technologies, Inc., a
wholly-owned subsidiary of the Quarterdeck corporation. StarNine develops
Internet server software for the Macintosh, including World Wide Web and e-mail
publishing systems. We'd also like to thank AOL, who
has supplied the hardware the main info-mac machine runs on.
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V15 #133"
Date: Mon, 30 Jun 1997 22:53:12 -0500
Subject: Applescript and PPP...
I've been trying to rewrite the PPP reconnect script that comes with
OT/PPP, and am running into a bit of proble. What I'm trying to do is have
the script first check if the connection is idle. If it is, I want it to
check to see if a specific process is running (Eudora Internet Mail Server)
and if it is, quit it. Then, connect to the server and restart the server.
The reason for doing this is because EIMS doesn't like it when the ISP I'm
with recycles the line, every six hours. Normally this wouldn't cause a
problem; it would simply cause OT/PPP to restart the connection. However,
it seems to run into a problem when the line disappears before the six
hours (Say, ISP restarts or loses the portserver I'm connected thru) and/or
the connection is dropped during the redial or ISP doesn't answer (For some
reason, OT/PPP won't redial if it the connection was opened when TCP/.IP
was called). The server reports that the stream for each part of the
connection (SMTP, POP, PORT106[what is that?], and something else) is
invalid, and halts. THe only restart is to quit and reopen.
What I'm looking for is to make the script compare a returned line from a
command for a certain string, the Application name. (tell application
"finder" to get name of processes)
I've found that this line:
tell application "Finder" to get name of process "Eudora Internet Mail
Server"
will return a string if the process is running and an error if it's not...
I could try to get that implemented but there's got to be a cleaner way to
do this... any suggestions?
(System 7.6.1, 'Power' Macintosh IIci with Daystar PPC Card)
Thanks.
Derek Jacobs - [email protected] - [email protected]
Date: Tue, 1 Jul 1997 20:54:48 -0400
Subject: Background driver for Imagewriter
}Date: Mon, 30 Jun 1997 11:36:18 -0600
}From: [email protected] (John Fitzgerrel)
}Subject:
}Does anyone know if a driver exists for the Imagewriter which
}works in the background? I have an old Imagewriter (pre
}Imagewriter I) which still works well, but it would be much
}more useful if I could let it run in the background. E-mail
}or posting will be greatly appreciated.
If you have a machine capable of running it, Apple's Quickdraw GX has an
Imagewriter driver which does background printing. I, too, have an old
Imagewriter that I bought with my 512k Mac way back when, and GX background
printing works perfectly with it using both my Powerbook 165 and my
Performa 6400. It's the main reason I run GX on both machines.
}TIA
}John Fitzgerrel
Paul J. Schinder
NASA Goddard Space Flight Center
Code 693, Greenbelt, MD 20771
Date: Tue, 1 Jul 1997 12:19:56 +0100
Subject: Desktop rebuild problem
Further to my recent posting regarding desktop rebuild problems on my
PowerMac 7100, I have identified the problem but not the 'cure'.
Many thanks to those who suggested the use of Tech Tool as a workaround.
This works well and has been added to my toolkit. Having delved deeper,
though, and reformatted the (Apple) drive using system 7.5.3 version of
Drive setup, I find that the problem does not reappear until the system
7.5.5 update is installed. This has been verified by twice following the
same procedure of reformatting the drive, installing 7.5.3, restarting and
rebuilding twice (to eliminate Mac Easy Open inspired rebuilds), installing
7.5.5 and restarting. At which point the rebuild key options do not work.
Weird, and not a problem on any other machine in my care.
Any thoughts on this would be welcome.
Trevor Harris, Lampeter
Date: Mon, 30 Jun 1997 21:01:51 -0500
Subject: DeskWriter 320 AppleTalk driver
I have an HP DeskWriter 320 that is able to be shared on an appletalk
network. However, the latest driver available on HP's website (v 6.0.3)
is for direct serial connection only. Does anyone have a version 6 driver
for networked DeskWriter 320's?
John R. & Lanni Park
Date: Tue, 1 Jul 1997 19:12:58 -0400
Subject: Find by time?
Is there a search application which is capable of searching an item on
local drives by time?
The more elaborate searchers can search by resource fork, data fork and
even comments in getinfo windows, but, I've yet to see something which can
search by time of day.
Date: Mon, 30 Jun 1997 19:52:43 -0800
Subject: Hundreds of fonts online: how best to organize?
I work at a print shop, and our Power Computing Power 100 (40 MB RAM/1 gig
HD/System 7.6.1) has about 700 fonts by my estimation, of which perhaps
200-300 are currently in use. The ones I use are stored in the Fonts
folder, inside the System folder, with the bitmap and TrueType versions
organized in suitcases by type (serif, sans, dingbat, etc.). The ones I
haven't used yet are in a separate folder, outside the System folder, and
are similarly organized in suitcases. I also have still more fonts in
folders I haven't had time to sort through. When I need to add a font for a
particular job, I have to quit all applications, drag the font between
suitcases, then re-launch the application(s) I need. Fortunately, this
doesn't happen often.
When I was running System 7.5.3, I tried Suitcase 3.0, but it informed me
that all of my suitcases contained Chicago, which they didn't, and I had
some other problems I can't recall, so I de-installed it. I am currently
running no other font management utilities.
I would like to be able to easily organize my fonts by type, view their
appearance in the font menu (as with Now WYSIWYG Menus, version 6.7 of
which deactivated itself when I upgraded to System 7.6.1, so I'm using an
earlier version of WYSIWYG Menus for the time being), and add and remove
fonts on the fly without closing applications. I would, ideally, like to
have all of my fonts available at any time, organized in hierarchical menus
by type, without bogging down those applications that steadfastly insist on
examining each installed font every time the application is launched. Word
5.1a takes long enough to boot now that I usually leave my desk and go do
something else while I wait.
Now WYSIWYG Menus allows you to rename and thus re-organize your fonts, but
it is dreadfully awkward at it (one font at a time, and much mouse-clicking
is required). I'd like to shift-click a few dozen font names, drag them to
a window or word that says "Serif," and have a "Serif" submenu appear in
all my Font menus. In other words, I'd like to organize my fonts in
precisely the same way I organize my files: nested hierarchical menus. Is
such a thing possible? It would also be very cool if I could define an
entire font category (specifically, Dingbats) to always display its
contents' names in plaintext rather than in their own character sets.
Oh, and one quick related question: in System 7.6.1, which STR# resource
contains the phrase "How razorback-jumping frogs can level six piqued
gymnasts"?
Date: Mon, 30 Jun 1997 20:47:36 -0500
Subject: Power Mac DebugServices
a quick and hopefully simple query:
while recently compacting my hard drive with norton utilities, my copy of
this program (Power Mac DebugServices v2.0b12) got hosed. what function
does this program perform? is it necessary to have on-board with 7.5.5?
where can i download the most recent version?
thanks in advance.
Date: Tue, 01 Jul 1997 13:10:39 +0000
Subject: TransCryptor (Cyr) 2.0
Dear Sirs,
Thank you for including the information on my TransCryptor (Info-Mac
Digest; Sat, 28 Jun 97; Volume 15 : Issue 128).
Unfortunately, this information does not reflect the most important new
features of the 2.0 version. If possible, please include in one of your
forthcoming issues the following info:
TransCryptor (Cyr) 2.0: new version
TransCryptor (Cyr) 2.0 (replaces the previous version 1.0) is a
HyperCard stack that allows to convert Cyrillic (Russian) TEXT files of
ANY SIZE from PC to Macintosh and vice versa. Input and output files may
be open and edited -in Russian- without any Cyrillic kit (and/or
Cyrillic fonts) present in your system.
New features:
• Conversions available from & to Apple Standard Cyrillic:
- Windows (CP1251),
- DOS CP866,
- DOS KOI8.
• Powerful Find&Replace function (the dialog box supports Russian
characters!).
[Archived as /info-mac/edu/lang/trans-cryptor-20-hc.hqx; 264K]
Thanks a lot.
Pavel Bondarovski.
Date: Tue, 1 Jul 1997 12:26:47 +0100
Subject: Type 11 errors (solved)
Many thanks to all who contributed to my Type 11 errors query. I have to
admit the cause was simple - a disabled Anubis 2.54 hard drive extension.
I was very chastened by this as I had just methodically tested the RAM in
various permutations in order establish which, if any, were faulty. This
was tricky as the RAM in the 8100 is installed in pairs!
Who or how this critical extension was disabled is a matter of internal
debate :-)
Date: Mon, 30 Jun 1997 20:47:06 -0500
Subject: VGA to Mac Problem
Toshiba Letter
Dear Sirs:
I purchased a Toshiba Multimedia Monitor, model # MM20E45, last week.
The salesman told me that it would work with
my Macinstosh Power Mac 7200 if I purchased an cable adapter. I purchased
a HD15F-DB15M to Mac Video Adapter and connected it to my computer. No
images appeared on the monitor screen. The salesman demonstrated the
moniter
hooked up to a DOS CPU and it worked beautifully. The adapter came with
four white pins attached and I don't know which ones to turn on--also, do I
need a different type cable to communicate with my Mac? Please help me
with this problem.
Doris A. Hill
--Info-Mac-Digest--
