Kaleidesktop Patterns
Icon, cursor and desktop pattern resources to decorate your environment.
Download: http://archive.info-mac.org/gui/grf/kal ... tterns.hqx
Kaleidesktop Patterns is a compliment to the great program
Kaleidoscope . I loved Kaleidoscope from the moment I installed it
except for one thing, none of my desktop patterns seemed to match the
different color schemes very well . So I created Desktop patterns to
match each of the different Kaleidoscope 1.5 color schemes. Hope you
like them.
Installation:
Requires the Desktop Patterns control panel (System 7.5 or greater)
1. Open the Kaleidoscope control panel and select a color scheme you
want. 2. Open the Desktop Patterns control panel. 3. Open the
Kaleidesktop Patterns folder, Drag & Drop the matching clipping onto
the Desktop Patterns window, then click the "set pattern" button. 4.
That's all folks.
