TypeForMe! v1.0
TypeForMe! v1.0
Download: http://archive.info-mac.org/gui/typeforme.hqx
TypeForMe! is a tool that lets you click with your mouse, rather than typing on your keyboard. It is an assistive program ideal for people with limited dexterity in their hands, and allows you to type by clicking an on-screen keypad with your mouse.
What is TypeForMe!?
TypeForMe! allows you to click on a onscreen keypad, instead of typing on a conventional keyboard. You are able to type all normal characters, upper and lower case, except for those requiring either the Command or Option keys to be depressed in combination with the typed key. However, the keyboard is still active on the keypad, so you would be able to type "Copyright © 1999". (The '©' symbol is made by pressing Option-G.)
Requirements
* MacOS computer with a 68020 processor or greater, including Power PC.
* 4 MB of application RAM (8 MB is preferable).
* MacOS 7.0 or greater.
Doug Jacobson
HyperSolutions
