Snap It! 1.0
Snap It! 1.0
Download: http://archive.info-mac.org/gui/snap-it-10.hqx
Snap it! is the definitive screen capture tool for MacOS. Contrary to other
screen capture tools available, Snap It! is a very low-level screen hacker:
Snap It! can take a picture of every part of the screen absolutely whenever
you want and save the result in a standard PICT file.
And most of all, Snap It! is freeware!
No more troubles in taking screenshots of programs like games which do not
give processing time to the Finder or to the classical screen capture
programs and prevent them from capturing the screen content.
Snap It! can capture in any bitdepth and in any size provided enough memory
is available.
If you can see it on screen, then Snap It! can capture it!
Snap It! may be freely distributed by online services, bulletin boards,
shareware collection CDs or non-profit user groups, as long as it is not
modified. This software may not be included in any commercial package
without the authorization of the French Touch.
© French Touch Softwares 1999
_____________________________________________________________
Pierre-Olivier Latour [email protected]
French Touch softwares http://www.french-touch.net
