Program Switcher v5.6.0J - Japanese Version
Download: http://archive.info-mac.org/gui/program ... -56-jp.hqx
This is the Japanese version of the Program Switcher package. A Mac OS X
version is under development.
Program Switcher is a convenient, timesaving control panel that allows you
to switch between the applications running on your System 7.1 through 9.x
Macintosh via a simple two-key keystroke. It was inspired by the same
function found in "Windows," but has been improved and transformed into a
unique and fully configurable control panel that makes switching
applications on the Macintosh as simple as pressing a couple of keys.
Key features include:
- The ability to switch, launch, quit, or hide any application with a
simple keystroke
- The ability to switch, hide, or close windows with a simple keystroke
- Full support for the latest MacOS technologies, such as Appearance,
Navigation Services, and Multiple Users.
- Elegant, unobtrusive interface that makes the seemingly simple task of
switching applications truly simple and easy to do.
- A powerful suite of user configurable hot keys, including such actions
as "Open File" and "Quit All Applications".
New in version 5.6.0 is the ability to define hot keys and add applications
to the launch/exclude lists by drag and drop from the Finder, plus a number
of minor bug fixes.
