Malph 3.0
Malph 3.0
Post by Info-Mac » April 30th, 1999, 9:00 am
Download: http://archive.info-mac.org/gui/malph-301.hqx
Enclosed is the latest version of Malph. If you have any old versions on
your server, please replace them with this one. The enclosed file is a
compressed, self-mounting disk image, so just double-click it to open the
image on your desktop.
Use Malph to switch between applications and to quickly launch commonly used
applications. To switch to another app, click on the application icon in
Malph. Malph also has a small indicator showing what process is currently
frontmost, which updates if you click in application windows to switch
between processes.
New with Malph 3.0 is the ability to create and manage multiple Malph
windows (documents). Other enhancements include a completely revamped
interface, support for deep icons (available when running Mac OS 8.5 and
later) and Contextual Menus. Take a look at the README HTML file included
for a list of major features that have been included in Malph 3.0.
Malph 3.0 requires PowerPC-based Macintosh running Mac OS 8 or later,
although it works best when running on Mac OS 8.5 or later.
Malph 3.0 is Shareware, which means if you use it you must pay US$12. Check
out the Register application enclosed with Malph for details on registering
Malph.
