Keep-It-Up Classic 2.5
Download: http://archive.info-mac.org/gui/keep-it-up-25.hqx
Keep-It-Up (KIU) is designed to keep your Macintosh server up and running.
KIU relaunches applications that crash, it can restart the Mac on a
regular basis and it can monitor free memory and disk space. It also
allows you to remotely manage and monitor your Mac (server) using a
webbrowser. KIU automounter will automatically (re)mount Appleshare
volumes on your desktop.
The primary function of KIU is to automatically relaunch applications if
for some reason they stop running (crashes, accidental quits,...).
KIU can also restart your Mac on a regular basis, which may improve the
"health" of the applications.
=46or remote management purposes, KIU has a tiny "embedded" webserver
(running on a port of your choice) that allows you to remotely
perform many functions such as: restarting the mac;
view, kill or restart running applications; launch applications;
run Applescripts; view logfiles generated by applications ...
KIU can send e-mail messages to you, actively alerting you of important
events such as : free memory or free disk space falls below a certain
preset level; an application gets relaunched; KIU restarts the Mac ...
Keep-It-Up Classic is designed for use with MacOS 7, 8 and 9.
Version 2.5 adds lots of improvements, most notably the KIU
automounter, which can automatically mount Appleshare volumes at
startup and remount these volumes if your Mac gets disconnected from
the Appleshare server.
KIU is $22 shareware (payment using Kagi).
Karl Pottie
E-mail:
The KIU web pages: http://www.vl-brabant.be/mac/
