Download: http://archive.info-mac.org/gui/itunes- ... er-110.hqx
Filename: itunes-skin-master-110.sit
Application Name: iTunes Skin Master
Version: 1.1.0
Category: Audio, Utility
Description:
Create, change, and download skins for iTunes. Customize your iTunes in
seconds.
iTunes Skin Master allows you to do three basic things:
-change skin of your iTunes 2,
-create your own iTunes skins,
-download skins from the internet.
Now you can customize the look of your iTunes without any special skills
quickly, and safely.
Skin Master lets you build your own skins, import existing iTunes
modification resources and download skins from the internet.
Customization of iTunes' visual look is now as easy as clicking one
button.
Author:
Lubos Tilka (Ancodia software)
Website: http://ancodia.com
E-mail: [email protected]
