Download: http://archive.info-mac.org/gui/fuzzy-find-macos.hqx
What is FuzzyFind for MacOS?
How was the file named I saved a year ago?
FuzzyFind for MacOS is a tool similar to Apples Find File placed in the
Apple Menu.
The advantage of FuzzyFind is, that it will find files which are named
not exactly as defined in the search string. It will ignore writing
mistakes and find all similar names.
For example if you search for "Account Meier", FuzzyFind will find all
documents which are named with "Account Mayer", "Account Meyer etc. Also
writing mistakes like "Acount" or "Accuont" will not influence the
search result.
FuzzyFind should not replace Find File from Apple. It is an extra tool
for very difficult search processes, where time is not so essential than
finding the right information.
