Download: http://archive.info-mac.org/gui/filetype-10.hqx
FileType is an application to change the file types (type- and
creator-codes) of files. You can save the file types you frequently use in a
database so you don't have to remember them. It's very easy to use and it is
Freeware.
Requirements: Mac OS 8.6 or higher with CarbonLib 1.3 or higher installed or
Mac OS X 10.0 or higher
Webpage: http://www.frederikseiffert.de/filetype/
Email: [email protected]
Distribution: May be included on any commercially available CD-ROMs of the
archives
