Desktop Transporter 1.2.0 - An easy-to-use remote desktop app for OS X
Download: http://archive.info-mac.org/gui/desktop ... er-120.hqx
Desktop Transporter is an application that makes sharing your desktop
with others, or yourself, very easy. Only a single click is required to
share your desktop with other Macs on your local-area network. It uses
Rendezvous to discover shared desktops, and provides you with the
ability to preview the shared desktop before connecting to it.
Desktop Transporter fully supports any number of attached displays, and
reconfigures itself on the fly to detect changes to your display
configuration. Naturally, you may protect access to your desktop using
a password, and a number of configuration options allow you to select
the performance level best suited for your network. You can also view
and control multiple desktops from different Macs on one Mac.
Desktop Transporter also supports copy-and-paste of almost any object
between local and remote displays. This version improves client-side
performance and fixes a number of bugs. Desktop Transporter now also
remembers the positions of its windows.
Desktop Transporter requires MacOS X 10.2.8 or later, and performs best
when the Macs sharing and accessing the shared desktop(s) are connected
via a high-speed local-area network. Desktop Transporter is $15
shareware. Screenshots and more information is available at the Desktop
Transporter home page:
http://home.online.no/~stoedle/YLS/YLS- ... orter.html
The Yellow Lemon Software home page is located here:
Daniel St¿dle and Yellow Lemon Software can be contacted at this e-mail
address: [email protected]
