Download: http://archive.info-mac.org/gui/copypaste.hqx
CopyPaste is the shareware utility that was awarded a 5
mouse rating by MacUser and was their shareware utility of
the year 1996. Shareware Junkies declared it Mac Product
of the year for 1997. CopyPaste also appeared in the June 97
Wired and has been featured in MacWeek, TidBits, MacAddict and
many other magazines. CopyPaste magnifies the clipboard in many
different ways and has been declared indespensible by web developers,
editors, writers, dtp professionals and everyone who uses
the clipboard.
CopyPaste is available online and can be downloaded free at:
http://www.scriptsoftware.com
it is also on the major shareware archives and AOL.
One of the early wonders of the Mac was its revolutionary ability to do
copy and paste across various applications. Unlike other areas in the Mac's
system software that have changed and progressed over the years, copying
and pasting has not evolved. How many times have you found yourself going
back and forth copying in one application and pasting in a different
application, wishing to yourself that you could copy 5-10 items at a time,
then go to another application and paste each of these items. Now you can
do not only this but view all 100 clipboards, save useful text and pictures
thru restarts and much much more.
**MacOS 8.5 compatible!
**Many advanced features but easy for beginners!
**Full Drag & Drop compatibility!
**Use up to 100 independent clipboards by menu or simple key commands!
**View and access all the clipboard using the CopyPaste Palette!
**Append text to 1 of 10 files on disk at any time!
**Process text, picture and net data on the Clipboards in many ways!
**Use a command key to switch and/or view all applications!
**Works great with iType, iSearch, iCount and iView Multimedia!
**New pop-up palette function and more!
**Clip Recorder - remembers the last 10 items copied via
command c.
**Clip Archive - copied data is appended to one of 10 text
files on disk.
**Save Clipboards thru Restarts - allows all 100 Clipboards
to be saved thru Shutdown or Restart.
CopyPaste eliminates tedious repetitive work and increases
your ability to get the job done.
Changes
In Version 4.3.1
€ bug fixes:
In Version 4.3
€ bug fixes:
- On Japanese systems the inline input method uses the Scrap Manager - very
strange. This caused problems with the Clip Recorder.
€ Many programs do NOT use the DeskScrap (=the public clipboard) for their
own copy and paste action, so CopyPaste sends these programs to the
background and back to the front in order to get the desired clip. You could
see this in previous versions when the program hides toolbars and other
window elements. This version patches certain routines so that the toolbars
stay on the screen, which accelerates CopyPaste`s performance. You can
switch this option off in the preferences if you have compatibility
problems.
€ Clip Sets now can be changed via hotkey. You can activate one of the ten
hotkey only works when the option "Use F2,F3, F4 Keys" is active, otherwise
none of the function keys is intercepted by CopyPaste.
€ The iconized Palette can now be docked at the bottom of the screen and
pops upwards when the mouse moves over it. Also a short delay for shrinking
and expanding the Palette is introduced.
€ A new Tag and Drop feature has been added. If Tag and Drop is active, you
can press ctrl,option,command and click the mouse between two characters of
a word. The order of the two characters will be reversed. This is intended
as a fast method to correct common typing errors.
€ The preferences now allow you to change settings for individual programs.
The previously hardcoded settings are already preset but can be changed.
The main preferences dialog contains the button "Application Exceptions"
which leads to the new dialog window.
€ The e-mail UnComment now works smarter and removes all levels of comments.
Additionally the text will be reformatted if the option key is pressed when
you select e-mail UnComment.
