CopyPaste-X 1.4
CopyPaste-X 1.4
Download: http://archive.info-mac.org/gui/copy-paste-14-x.hqx
Press Release
6/24/2002
CopyPaste X 1.4 Released for OS X
CopyPaste is the original award winning multiple clipboard utility and with
the 1.4 update it is better then ever. Productivity is what its all about.
It can be downloaded from versiontracker.com
http://www.versiontracker.com/moreinfo. ... 795&db=mac
or from:
http://www.scriptsoftware.com
CopyPaste is the digital hub for clipboard material and many other kinds of
data. It is easy to use, saves time and allows you to do less and accomplish
more. Try it and see how critical a clipboard manager is for OS X.
Users rave about CopyPaste X here:
http://www.scriptsoftware.com/copypaste/usersViews.html
New Features in Version 1.4:
¥ CopyPaste-X now can communicate with CopyPaste 4.5 Classic. If both
versions are installed CopyPaste-X can copy and paste its clipboards between
OS X/Classic seamlessly.
¥ CopyPaste-X is localized in Danish
¥ CopyPaste-X can now read the OS 9 SimpleText files with embedded pictures.
¥ CopyPaste-X can now read RTFD files. You can open .rtfd files and save
them in .rtf format which in turn can be opened by MS Word or Apple Works.
¥ CopyPaste-X can now paste plain text without style information by
option-clicking a palettes "P" button
Improvements:
¥ The Clipboard Editor is much much faster
¥ The main toolbar for the Clipboard Editor is initially not visible and can
be located by the "Show Toolbar" command in the "Edit" menu
¥ The word-list creator now can deal with Japanese text in different fonts.
¥ The Editor now supports anti-aliased text on OS X 10.1.5 and higher.
Bugfixes:
¥ Insert long Date was partly broken, it works now
¥ Setting background color to "other" was broken and is fixed
¥ Clip Archive function initially created a wrong file type which somtimes
caused garbage onscreen.
One of the early wonders of the Mac was its revolutionary ability to do copy
and paste across various applications. Unlike other areas in the Mac's
system software that have changed and progressed over the years, copying and
pasting has not evolved. How many times have you found yourself going back
and forth copying in one application and pasting in a different application,
wishing to yourself that you could copy 5-10 items at a time, then go to
another application and paste each of these items. CopyPaste gives you this
and much more. It turns out that having additional clipboards is incredibly
useful. CopyPaste eliminates tedious repetitive work and increases your
ability to get the job done.
CopyPaste-X magnifies the clipboard in many ways.
* Clipboard Extender - adds an infinite number of easy to access
clipboards via menu or key command. Without CopyPaste the Mac has only one
clipboard.
* Clip Recorder - remembers the last 10-200 (user selectable) items
copied via command c and keeps them in a stack.
* Clipboard Editor - Edit any clipboard by simply double clicking in any
clipboard palette.
* Save Clipboards thru Restarts - allows all 10 Clipboards to be saved
thru Shutdown or Restart. Without CopyPaste the Mac does not save its
clipboard.
* Drag and Drop - allows dragging anything to and from the CopyPaste
Palette. Not only selections from a program, but also text, picture, sound
or ClipSet files can be dragged. Now uses Quicktime to read files.
User groups, manufacturers and magazines can contact us at the email below
for more information.
Thanks for Trying CopyPaste
julian
///\ J u l i a n M i l l e r
\\\/ S c r i p t S o f t w a r e
\\\/ CopyPaste, KnowledgeMiner, PhotoMover, Easy Card Creator
///\ PhotoCircus, PhotoJuster, ELI, Touch3D, Project Timer
\\\/ http://www.scriptsoftware.com julian@scriptsoftware
For occasional news about Script Software products and updates
send an empty message to [email protected]
to remove an old email address [email protected]
