Download: http://archive.info-mac.org/gui/clipboard-edit.hqx
Clipboard Edit 1.0 [2000/10/26]
by Vincent Jalby, [email protected]
http://members.aol.com/vjalby/
Product description
Clipboard Edit is a simple application which allows to edit the content of
the clipboard (both text and graphic clipboards). You can save it as a
clipping file or as a SimpleText file. Moreover, you can use several
filters to clean up and convert text clipboard.
System Requirements
Clipboard Edit runs on any Power Macintosh with Mac OS 8.1 and later.
Shareware Fee
Clipboard Edit is freeware.
This product may be included on the commercially available CD-ROM of the
archives.
