Appearance Designer1.1
Download: http://archive.info-mac.org/gui/appeara ... er-111.hqx
Appearance Designer is a simple utility to create your own color scheme
and to add it in your appearance control panel.
I hope you make your Mac more exciting and more customized for your own
sense.
Basically, Appearance Designer runs with Appearance Control Panel,so you
at least need your machine installed Appearance System Extension
(Appearance Control Panel). If you are currently using Mac OS 8 or Mac
OS 8.1, don't worry. Appearance System Extension has been installed when
you installed Mac OS 8 or 8.1, or If you are currently using System 7.1
or later but Mac OS 8, you must install Appearance System Extension at
First. If you don't have it, you may get that at Apple's Web Site.
If you use System 7 or more earlier version of System, you can't run
this utility because Appearance System Extension does not support its
version of System.
I have no responsibility for any disaster and anything which happens to
you in a bad way or another
by using this software. Please use it at your own risk.
email [email protected]
