Alias It 1.0
Alias It 1.0
Download: http://archive.info-mac.org/gui/alias-it.hqx
Alias It version 1.0
Alias It is a $5 shareware utility that enables you to create multi-alias
files, allowing you to open more than one file with a click of the mouse.
You can create aliases of any Macintosh file, similar to the existing
alias feature on the Macintosh OS. The main difference is that Alias It
enables you to store multiple aliases within a single, double clickable
file.
Alias It is a drag and drop utility. You simply drag the file, or group
of files that you want aliased onto the Alias It icon and it creates a
multi-alias file. Once created, you can simply double click it and watch
it open the group of files for you. The files will be opened in the order
that they were added. There is no user interface other than what the
Finder provides.
Two versions of Alias It are provided. A System 7 version using the older
two-dimensional icons, and a System 8 or later version, using the newer
three-dimensional icon set.
More info available on the following website:
http://ourworld.compuserve.com/homepages/orchardsw
If you have any questions or comments please send email to:
