Download: http://archive.info-mac.org/text/wp/joh ... r-2-wp.hqx
This set of five macros for WordPerfect 3.x:
1) goes through all open windows, asking for each if you want to save and
close, just close, or leave open. You can opt to close all windows at
once, save all, or print all.
2) tiles all open windows horizontally, rather than to the pattern of
approximate squares that the program command produces, so you can read
whole lines of text. Tiles windows to standard width.
3) tiles windows horizontally as above, but to the width of the screen.
4) opens a new view of the active window, independently scrollable so you
can view two parts of one document at once.
5) toggles between the top two open windows, saving you the trouble of
cycling through all open windows or selecting the window by name from the
menu.
New in this version: Save All and Print All commands; Tile commands are
button-bar aware; and Close without Saving prompts you to confirm your
choice.
Free for non-commercial distribution and use. May be included on UMich and
Sumex CD's.
John Rethorst
