Download: http://archive.info-mac.org/text/qark/s ... rds-10.hqx
Short Words will save your time spent on composing documents in
QuarkXPress 3.3 or later. It automatically places unbreakable spaces
after the short words you don't want to stay alone at the end of
line. You can choose to handle one-letter words, two-letter words,
numbers and currency symbols, and you can apply Short Words to either
selected box only, or the whole document.
The Short Words XTensions software can be used for English, French,
Spanish, Czech, and several other languages. It's behavior is easily
configurable in a dedicated preferences dialog window. Installation
process is so simple that you can start using Short Words just a few
seconds after downloading it.
