BBEdit Extensions (Insert Column & Spaces to Tabs)
Download: http://archive.info-mac.org/text/bbe/sp ... nsions.hqx
This is an update to the two extensions that I posted earlier.
(a bug in Spaces to tabs)
Please replace the ones in the archives with this file. I'm including sources
for the two extensions also.
In keeping with the other extensions, these are freeware so enjoy.
Here are two extensions for BBEdit that I needed for processing some
mainframe data for importing into a database.
"Insert Column" puts a tab at the current insertion point in every line of the
file.
"Spaces to tabs" replaces all spaces with a tab character.
I don't know where to send the source to, so I just upload these as is.
After being spoiled by using McSink, I won't be truly happy with bbedit
until it contains all the features of Mcsink. :-)
Two down, two dozen more to go...
Matthew Xavier Mora
__________________________________________________________________
Matthew Xavier Mora The keeper of the UMPG
SRI International [email protected]
[Sent using Eudora 1.3] [email protected]
