BBEdit Remote Link Checker 1.1
Download: http://archive.info-mac.org/text/bbe/re ... ker-11.hqx
The BBEdit Remote Link Checker is a shareware BBEdit extension for web
authoring that allows you to check all of the remote http and ftp links in
a web page. It installs a "Check Remote LinksŠ" command to the internet
window. An error browser window is used to present the bad links. It is
compatible with BBEdit 3.5 or later, including BBEdit Lite.
Version 1.1 adds a more extensive progress dialog, and also makes it modal
so that you can switch to other applications while links are being
checked. It also has several bug fixes.
For more information, see .
Dan Crevier
