BBEdit Plug-Ins for MacPerl Rel. 6.0
Download: http://archive.info-mac.org/text/bbe/ma ... ug-ins.hqx
I have written several BBEdit plug-ins that facilitate the use of BBEdit and
BBEdit Lite with MacPerl (a Macintosh port of the Perl programming language).
This is release 6.0 of the plug-ins. The plug-ins included are:
1. Run MacPerl (version 1.2) - updated
2. Check Perl Syntax (version 1.2) - updated
3. Run MacPerl Front (version 1.2) - updated
4. Run File with MacPerl (version 1.2) - updated
5. Edit MacPerl Script (version 1.0.2)
6. Shuck (version 1.0.1) - updated
7. Perl Filters (version 1.1.4) - updated
8. Perl Palette (version 3.1 by Lindsay Davies)
Some changes from the previous release are:
1. The plug-ins will attempt to launch MacPerl if it is not running when used
with BBEdit Lite (formerly the plug-ins would only attempt to launch MacPerl
when used with BBEdit, not BBEdit Lite).
2. An option was added to the Run MacPerl plug-in to send STDOUT and STDERR to a
file with a name based on the name of the file containing the script that is
run.
3. The Run MacPerl plug-in is scriptable.
4. BBEdit file groups are listed in the floating window of the Perl Filters
plug-in.
The plug-ins are freeware. More information is available on my BBEdit plug-ins
web page:
http://pobox.com/~bradh/bbedit
Brad Hanson
