BBEdit HTML Tables version 1.0.2
Download: http://archive.info-mac.org/text/bbe/bb ... es-102.hqx
Tables are one of the most useful parts of current HTML (Hypertext Markup
Language). They make it possible for designers to create documents on the
web which have a much more robust structure than was possible with HTML
prior to their introduction. BBEdit HTML Tables was written to extend the
capabilities of the BBEdit software, which is one of the best ways of
coding pages if you know HTML. The intention with this software has been to
produce something that while unfortunately not WYSWYG (essentially
impossible in an extension to BBEdit) is as easy to use as possible, while
also allowing the creation of complex tables.
BBEdit HTML Tables implements tables as per the Netscape 1.1 specification.
BBEdit HTML Tables has been extensively tested on versions 3.1.1 and 3.5
Lite of BBEdit. It requires a version of BBEdit that supports extensions,
which means version 3.0 or later. This software is shareware, with the low
fee of US$5 payable directly or via Kagi. Please read the enclosed read me
for details.
Version 1.0.2 should replace earlier versions, it adds the ability to undo
as well as fixing some minor bugs in the menus and preferences.
Stephen
Dr. S J Marshall
Victoria University of Wellington,
Home Page: http://www.vuw.ac.nz/~marshall
