String Generator Pro 1.0
Download: http://archive.info-mac.org/text/string ... pro-10.hqx
What is String Generator Pro (SGP) ?
SGP is a tool for all you boys & girls who have to handle with
structurated text, e.g. programming source code like Pascal, C, C++,
Basic, JavaScript, Java, HTML. SGP is also very useful when you want fast
and simply to build a table or a report or when you want to numerize
something.
The big diffrent between SGP and an normal text-editor, that SGP is not
able to edit any text, instead of this you are generating the text you
need.
SGP has a lot of features to do things like that very fast and easy. It
has great drag&drop support, which includes dropping of files & folders
(e.g. drop hunderts of picture files on SGP to create the img-tags for
your webpage).
SGP has great features:
- 'Generate on drop' (autogenerate strings by simply dropping text or
files on SGP)
- multiclipboard (you can drop more then one thing at the same time and
don't care if you just need this text later)
- save your string commands if you need them often without any
file-dialogs
- minimize-button to keep your screen free
and a lot of more things...
Just visit the SGP-Website to learn more about SGP, to see great examples
and Gif-animations which shows best the work with SGP.
http://www.robs-world.de/software/sgp/
Have fun generating string!p://www.robs-world.de/software/sgp/
