Download: http://archive.info-mac.org/text/perusa ... r-10b1.hqx
Perusal 1.0b1 a large text file browser
Perusal is a text file browser. You cannot (yet) edit a file with
Perusal, just look at it. The big benefit of Perusal is that you don't
need gobs and gobs of memory to look at large files. Perusal is a
file-based editor that only reads small pieces of the file at a time.
Perusal can display tabbed text in the same way most word processors do,
or it can force the text to align in columns like a spreadsheet (this is
useful for tab-delimited files of exported information). Tabs are
user-settable. You can also copy text from the file onto the clipboard,
or save selected lines into a new file.
Perusal requires a computer running MacOS 7.0 or later with either a
68000 or higher CPU or any PowerPC.
Perusal is $10 shareware.
Perusal may be included on the Info-Mac CD.
Ken Worley
[email protected]
