Multi Find-Replace 1.5
Download: http://archive.info-mac.org/text/multi- ... ace-15.hqx
Multi Find-Replace (MFR) is a free FKEY that rapidly performs a
succession of "Find and Replace" operations on the current Clipboard
contents. As shipped, MFR will operate on the Clipboard if it contains
TEXT.
The package contains pre-defined MFR definition files:
"DOS Mac text conversion"
"Softwrap / ASCIIfy"
"UPPERcase / lowercase"
"Quote / UnQuote email"
Currently, you use ResEdit to create or modify MFR definition files.
Version 1.5 mainly fixes problems found in 1.4. It has been tested on
various systems versions up to 7.5.5.
