MacWinText 1.0
MacWinText 1.0
Download: http://archive.info-mac.org/text/macwintext-10-fr.hqx
MacWinText 1.0 - this program allows you to convert text and RTF files from
Windows to Macintosh format and vice versa. Drag and drop the files and folders
you want to convert onto the program icon: the program will do the work for you.
You can, at one go, convert Macintosh and Windows files.
Gérard Sebbah
BTW: if you need any information, please, e-mail to
